Proxi in Panda
Zwierzak
Proxi in Panda
Post by Zwierzak »
Hello!
I Have a problem after Proxi procedure in Panda. After procedure external temperature indicator disappeared from dashboard? Does anyone know why and how to fix it?
Re: Proxi in Panda
I saw in another thread that you actually changed the Instrument Cluster and the temperature does not show on the new one. Is this correct?
Zwierzak
Re: Proxi in Panda
Post by Zwierzak »
Yes I've changed the Instrument Cluster.
After I changed it it there was temperature in this new one but the milage indicator was blinking.
Then I did Proxi and temperature disappeared.
Any idea how to fix it?
Re: Proxi in Panda
Did the old instrument cluster show correct temperature?
Zwierzak
Re: Proxi in Panda
Post by Zwierzak »
The old one was basic version without temperature and RPM-meter. I borrowed also the third one with temperature and it is working well but the odometer is blinking because I haven't done proxi yet because I'm afraid that the result could be the same.
Re: Proxi in Panda
Ok, I understand now...
Can you find the log file from the proxi alignment and send it to me (in PM).
wojtassslg
Re: Proxi in Panda
Post by wojtassslg »
In the future it will be able to make a proxy on the counters from gasoline to the diesels?
Re: Proxi in Panda
No, it is not possible to exchange instrument cluster between diesel and gasoline. It is a limitation of the firmware inside insrument cluster (and in most cases there are physical differences).
wojtassslg
Re: Proxi in Panda
I understand that in the other direction is the same?
Abraa
Re: Proxi in Panda
Post by Abraa »
same thing with temperature happened to me. It might be that Body Computer says there's no temp reader and instrument cluster gets this information while proxying so It turns the option off. Is there any fix for that already? Also Yani, are you planing to add milage fix, so that instrument cluster shows the milage stored in Body Computer? I'm not sure how they'll react on car test if they found that in between 2 years car changed milage from 80000 to 15000 ;)
Fiat Panda 1.1 2004 & Fiat Punto 1.2 60 1998
