Multiecuscan 2.8.2 RELEASED!!!
Re: Multiecuscan 2.8 RELEASED!!!
delta-c wrote:Hi,
does this version now really supports the first Hitachi MPI ?
Simon
I cannot confirm that it is working on this ECU yet. You can test it yourself (if you have a car with this ECU)...
159sportwagon
Post by 159sportwagon »
hi yani. i download the version again and it is run. i try the new version on my car .
pandamonium
Post by pandamonium »
hi,
does 2.8 include panda proxy alignment? cant seem to find it,even though it shows on supported vehicles.
thanks,gary.
pandamonium wrote:hi,
thanks,gary.
Yes, it is included. However, due to a bug, it is not showing in the list when you select Panda...
You can use the PROXI Alignment procedure from Punto '03 or Croma '05 until I publish a fixed release....
viewuser
Post by viewuser »
yani wrote:What is your operating system?
Which .NET Framework versions do you have installed?
It's SP pro SP3 with 4.0 net framework.
the 2.7.2 works but not the new :cry:
thank
viewuser
Post by viewuser »
see pics :(
alfiat
Post by alfiat »
Hi Yani,
I also confirm that my update to 2.8 is not working.
Tell what to do.
Regards,
Alfiat
alfiat wrote:Hi Yani,
Tell what to do.
Regards,
Alfiat
Are you getting the same error - "Common Language Runtime detected an invalid program" ?
alfiat
Post by alfiat »
Yes Yany the same.
If I select "continue" the program says LOADING in the middle of the screen and nothing happens.
I even tried to download again and install but the error is the same.
The program is passing the part of registering.
It is the firs time that this is happening. I am using as usual XP Professional and the correct Framework.
Regards,
Alfiat
alfiat
Post by alfiat »
Hi yani again,
I even tried right now to reinstall Framework 2.0 but the error in starting FES is the same.
Regards,
alfiat
