Multiecuscan 2.8.2 RELEASED!!!
I released Multiecuscan 2.8.2 today to fix the connection problem with earlier Hitachi ECUs with VagCom/KKL interface.
Earlier versions of Multiecuscan worked properly with this ECU only when using OBDKey interface but failed with VagCom/KKL.
Here is a list of the changes in 2.8.2:
- Fixed the connection problems with earlier Hitachi ECUs
- Support for Siemens Body Computer (Panda)
- Support for Selespeed CFC228F Automatic Gearbox (Punto, Panda, Idea, Musa, Ypsilon)
I released Multiecuscan 2.8.1 today to fix PROXI stability and Grande Punto/Punto Evo/500/Mito communication problems.
- Improved PROXI Alignment Procedure stability
- Improved communication stability for Grande Punto, Punto Evo, 500, Mito
- Added Fiat Panda PROXI Alignment procedure
I released Multiecuscan 2.8 today.
Here is a list of the changes:
- Fixed a problem with PROXI Alignment Procedure in Fiat Bravo '07, Croma, Alfa 159, Alfa GT, Alfa 147
- Support for AISIN AF40-6 Automatic Gearbox (Croma, 159, Brera, Delta)
- Support for Delphi Body Computer (Grande Punto, Punto Evo, 500, Qubo, Doblo, Mito)
- Support for Marelli Instrument Panel (Grande Punto, Punto Evo, 500, Qubo, Doblo, Mito)
- Support for Marelli Instrument Panel (Croma)
- Support for Siemens Instrument Panel (159/Brera)
- Support for Marelli Body Computer (Bravo, Delta)
- Added Service coupons function for Stilo to set the number of remaining service coupons
- Improved touchscreen support
- Added Logistic mode (supplier low-power mode) deactivation function (Grande Punto, Punto Evo, 500, Doblo, Mito, Bravo, Delta)
- Support for Bosch XENON headlights
- Support for Valeo XENON headlights
- Support for Litronic XENON headlights
- Support for Selespeed CFC300 Automatic Gearbox (Grande Punto, Punto Evo, Qubo)
- Support for EDC16C39/CF5 Diesel Injection(1.6, 1.9, 2.0 engines - Bravo, Delta, Linea, 159)
- Added PROXI Alignment Procedure for Grande Punto, Punto Evo, 500 and Mito (still in experimental mode)
- Fixed IMA injector coding function for Grande Punto, Punto Evo, 500 and Mito
- Added Grande Punto, Punto Evo, 500 and Mito support with OBDKey interface
- Fixed a problem with DTC reading on Bosch Monomotronic MA1.7.3
- Fixed "Air quantity" reading on Bosch Motronic M2.10.4
159sportwagon
Re: Multiecuscan 2.8 RELEASED!!!
Post by 159sportwagon »
hi yani, i download the version 2.8. after i install the version 2.8 , the fes will not start. at the desktop open a window and said -not right parameters- ??? can you help me.
viewuser
Post by viewuser »
I have problem me too with the new FES at begining :cry:
See the message
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidProgramException: Common Language Runtime detected an invalid program.
at .()
at  .(Object , EventArgs )
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Multiecuscan2
Assembly Version: 2.8.0.0
Win32 Version: 2.8.0.0
CodeBase: file:///C:/Program%20Files/Multiecuscan/Multiecuscan2.exe
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Thank
159sportwagon
and i can not install fes 2.7.2 , too??
What is your operating system?
Which .NET Framework versions do you have installed?
159sportwagon
what is net framework?
159sportwagon
i have windows xp home edition, service pack 3
piscinarasx
Post by piscinarasx »
hi yani, i download the version 2.8. after i install the version 2.8 , the fes will not start. at the desktop open a window and said -not right parameters- ??? can you help me.i have xp pro.
piscinarasx
works.
excuse the inconvenience
delta-c
Post by delta-c »
does this version now really supports the first Hitachi MPI ?
Simon
