Closing windows with the remote key AR 147
DiReCtX
Re: Closing windows with the remote key AR 147
Post by DiReCtX »
Hi Yani sorry that so long did the report but had no access to the second car
FESLog_1012051704_ALFA 147 1.9 JTD 16V.txt
CAN without this function (with Data Configuration)
(1.92 KiB) Downloaded 616 times
FESLog_1012051645_ALFA 147 1.9 JTD.txt
CAN Log with closing window (with Data Configuration)
(1.76 KiB) Downloaded 634 times
FESLog_1012051653_ALFA 147 1.9 JTD.txt
(2.67 KiB) Downloaded 635 times
Houterman
Post by Houterman »
Any news on this request?
Kind regards
Alfa 156 1.9 JTD 105HP
Alfa 147 1.9 JTD 16V 140HP
Alfa 155 1.6 TS 120HP
Yes, I'm working on this....
dallas140cv
Post by dallas140cv »
The superclosure is enabled by the presence of anti-pinch on each door. The anti-pinch can be simulated by a resistance of 330 ohm, if i remember well. The door ecu shall be also of the type enabled (from end-of-line programming) for superclosure (all ecu from Distinctive 2000-2002 are enabled). On my 147, i have placed an enabled door ecu, i have simulated the anti-pinch. At this time, the superclosure was functioning. After a proxy alignment made with Examiner in Alfa Romeo garage, instead, the superclosure is disabled.
DiReCtX
Post by DiReCtX »
Any news about this ??
Regards
The function is available in Multiecuscan 2.7.2, in PROXI Alignment procedure for Alfa 147.
However, It will probably not work without anti-pinch sensors.
marqo
Post by marqo »
I will generate the file for 159 without superclosure. I added anti-pinch on drivers door and now I just need to activate this feature in BC. Will be here anybody, who can generate the log file for 159 with superclosure?
marqo
Post by marqo »
As promised log file from my car in attachemnt
FESLog_1103261647_ALFA 159 1.9 MJET 16V.txt
CAN Log without closing window
(3.24 KiB) Downloaded 500 times
maunu
Post by maunu »
Log file of 159 remote closing windows.
I'm not sure if the log is correct so if more info needed please let me know and I will try to make better log file.
FESLog_1103302217_ALFA 159 2.4 MJET 20V.txt
(2.6 KiB) Downloaded 515 times
bubu321
Post by bubu321 »
i'm a people with 147 (2006 ) who wish to test...
- my car is not closing window.
