Multiecuscan Alfa Romeo 159
Benzina159
Post by Benzina159 »
Hi everyone, i own a Alfa Romeo 159 2.2, i have a elm box and cable and would like to use it on my car with multiecuscan, i cant seem to connect to my car though, i looked at the compatibility list and the 159 is on there so what may i be doing wrong? the correct port and port speed is set and all the tests pass. please help me?
elguru
Re: Multiecuscan Alfa Romeo 159
Post by elguru »
come faccio a resettare service alla mia alfa 159 19 jtdm 16v con fap che dopo averlo resettato mi dice di sostituire l'olio.
Tanis8472
Post by Tanis8472 »
Looks like you need the registered paid for version as all the things are in red writing.
HTH
amiko
Post by amiko »
HI!!!
I have bought ELM327 and installed driver for it on Windows 7 (http://www.ftdichip.com/Drivers/VCP.htm) 32bit.
I have chosen my car in selection (Alfa Romeo 159 2.2JTS 16V), in settings menu defined ELM 327 v 1.3+ and correct port (COM6) and correct speed 38400 but multiecuscan can not connect to my car. Though, TEST shows that everything is OK.
Please HELP!!!
radu_gostian
Post by radu_gostian »
Try useing the latest version 3.2
no pain, no gain
amiko
Post by amiko »
radu_gostian wrote:Try useing the latest version 3.2
I have 2.6 version.
It should be working.
I think that multiecuscan management should give some explanation about this fact.
I am very dissapointed of this software.... :(((
Juggers2k
Post by Juggers2k »
I have 2.6 version.
There is a lot more coverage in version 3.2 than there was in version 2.6.
If you have a legitimate software license you should be able to download v3.2 from the website and just install it over the top.
Then try again and it may work.
If you're using an illegally hacked version of 2.6 then that wouldn't apply.
amiko
Post by amiko »
Here is the resoult of my trying to TEST multiecuscan:
And here you can see the full resoult of TEST:
RESPONSE: ATZELM327 v1.4>
RESPONSE: ATE0OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: ELM327 v1.4>
Did you try the "Scan" function? And did it find anything?
Can you connect to the engine ECU? If you can connect to the engine but cannot connect to other modules then your problem is the same as described in this thread: viewtopic.php?f=5&t=1493
amiko
Post by amiko »
yani wrote:Did you try the "Scan" function? And did it find anything?
I have even downloaded newer version 3.2 DEMO to try and NO RESULT.
HERE IS MY PROBLEM! :(
WHAT CAN I DO???
