Fiat 500 1.3 MJT "Reset oil service" ?
Michuts
Post by Michuts »
Hi friends ;) ,
I'm from France, excuse me for my poor English lol :D I have a 2007 Fiat 500 1.3 MJT.
I'm working with multiecuscan 2.7 Registered version and a ELM327 interface V1.4.
All is ok, communication between interface, OBD and the soft is ok no problem.
The only problem I have is that I can't reset with the soft the "oil service" message (in french : "vidanger huile moteur") and the red light "oil pressure" is still flashing.
I'am using - as asked in the Supported Vehicle page - the adapter cable 3 for the "Service Interval Reset", communication is Ok I can read all the service parameter.
But I can't reset that message :( ...
Of course the oil level is Ok and there's no problem with the oil pressure.
I search on the forum about that but I didn't find anything :roll:
Any idea ? Can multiecuscan do that ?
Greetings From France, Michuts ;)
Re: Fiat 500 1.3 MJT "Reset oil service" ?
Hi Michuts,
Yani wrote on some topic about that... but I can not find that topic... :roll:
Anyway, multiecuscan can not, at the moment, reset the "oil service" message.
It can only reset the "Service Interval Reset"! :roll:
One guy from forum have the same problem on Alfa Mito... :roll:
Actually, this function IS available for 1.3 MJT....
You have to connect to the engine and go to Adjustments. There is a function called "Oil Change". Just execute this function and it should reset the message.
Michuts
Post by Michuts »
Hi Alfa156sarajevo, Hi Yani ;-)
Thanks a lot for the answer. I'll try that on Saturday, i'm not actually at home.
I'll tell you if it's ok or not.
Many thanks, Michuts ;-)
peko
Post by peko »
hi friends
ok, but problem is on fiat 500 just elm interface work, but to scan ecu is one configuration and to scan dash, you must change configuration
i say configuration, the pin number in obd !
maybe anybody have solution to shint obd pin or made one adaptator ???
