VAG KKL cable connections
Fermas
Re: VAG KKL cable connections
Post by Fermas »
Can someone help me?
With your settings it can have nothing to do, you are coming into the ECU and airbag.
I know that sometimes the connection does not work to control
but on other vehicles it works again.
Try using a different laptop
A friend could not connect with the netbook
Only after he has carried his tower PC in the garage. it has
it works without Problleme.
Test it again with another PC
Greetings
Darkman
Post by Darkman »
hello
As a colleague wrote - try to use another laptop, or use a newer version of the FES 2.6.1 or 2.7
Here on the forum and wrote that the Polish forums pepole did write FES 2.6 had problems (bugs) with such things is that it ECU engine and connects the airbag is no longer with the res
ipivan
Post by ipivan »
Hi to all!
I have a cable like this from top of page 3(photo),VAG-COM KKL.
I can't build connection to Alfa156 1.8 16V 2003.,FES ver2.7.2.
The cable works with VW on COM 4.
When I start searching interface,FES can't see the cable.
Any ideas......?
Regards!
demssite
Post by demssite »
Hi, in this cable below, i don't really understand what does it mean the 12/13 position. It seen to have a 4 position slider switch, but i don't know what it slide between to.
Thanks in advance.
Diego.
Darkman
Post by Darkman »
12/13 by producer it's for : park sensor, dark sensor, Cabin lighting .... Of course, if you have them in the car :D
I once had the opportunity to see into such an interface
The pin 13 was not used on this interface. but the pin 11
Just not named on the Edikett.
There are some KKL interface on the market that are provided for this switch and can be retrofitted.
demssite
Post by demssite »
I'm waiting for a 4 position slider swith i've bought online to retrofitt a KKL cable, but i don't really understand if i need to use this scheme like in the photo I posted before with 12/13, 1/9 for ABS, 3 for Airbag and 7 KKl/Engine. I'm a bit cunfused. The swith is like this one:
mattydr67
Post by mattydr67 »
I don't understand why you want to complicate things?
If you chose to use this interface just for Fiat group you can do it very simply way.
You need just a 2 positions DIP Switch.
Position 1 : go to pins 1,7,8,9,11,12 and 13 ( soldered together )
Position 2 : go to pin 3 ( airbag )
This is to separate airbag ( just becasue one of us said that is better to separate airbag controler and the other ones can be soldered together )
meralvina
Post by meralvina »
Hello everybody,
I need a little help:
Is that possible to use VAK KKL usb interface to read codes on Opel Astra 1997 1.6 16V Engine: X16XEL ?
In case of positive, what software to use ?
Thanks.
