Multiecuscan 2.7.1 RELEASED!
Pablos_g
Re: Multiecuscan 2.7 RELEASED!
Post by Pablos_g »
thanks YANI. great job.
I have a question. It is possible to add airbags MY95?
WILDCARD
Post by WILDCARD »
I have version 2.6.1 registered.
How do update to version 2.7?
any help will be appreciated. Do have to purchase the license again?
Greetings from South Africa
bas
Post by bas »
WILDCARD wrote:I have version 2.6.1 registered.
Uninstall 2.6.1, download and install 2.7.
License is kept in windows registry and will be automaticly tranfered to new instalation.
BAS
WILDCARD
Post by WILDCARD »
BAS
tHANK YOU VERY MUCH WILL DO SO.
Shadeyman
Post by Shadeyman »
Download 2.7 and let it install over the old version. This way it will keep all the settings you've made.
Present Software
Multiecuscan v4.7 Registered
FES Dashboard
Present Cars
2011 FIAT 500 TwinAir
2011 VOLVO XC60
159sportwagon
Post by 159sportwagon »
hello, i mean this is a problem fron multiecuscan 2.7 . i try to reading the airbag eco on a fiat punto 188 (year built 2006) . and connected fault. ?????????
Darkman
Post by Darkman »
hello ;)
actually if you want to connect to the airbag in the Alfa 166 is an inscription which is entered here(adaptercable 2 RED). No matter whether you check or ELM327 .
Now, I tried (without connecting to a car) to try this in the FES 2.6.1 and everything is fine but i have VAG KKL to. The program displays a message CONNECTING ECU PLEASE WAIT
So try with the older 2.6.1 FES
You cannot connect to the airbag with ELM interface. The ELM interface simply does not support the airbag communication protocol.
You need VagCom/KKL interface for the airbag. See http://www.multiecuscan.net/SupportedVehiclesList.aspx
I agree with Shadeyman ;)
That is how I 'm doing! And it is working great! ;)
Daniel_fe
Re: Multiecuscan 2.7.1 RELEASED!
Post by Daniel_fe »
Hi, I wonder if there is potential to incorporate, to multiecuscan, a Brazilian model Palio with iaw MM 4sgf ECU. Achievement serial communication and can, but in search of actuator data are not consistent with the statement, and not all are verified. The CAN bus iso code (BC): 40 83 83 B6 9B, motor: 07 D9 85 0D C7 and control boxes 32 83 19 83 26 :D
Thank you
