ALFA 156 2.4 JTD connection problem
skylight75
Post by skylight75 »
Hi all
I have a problem connecting to my ALFA 156 JTD '99
i am using both interface KKL and ELM 327 1.4
with both i can not connect to the ECU
i got the error as you can see in attached image
alpha
Re: ALFA 156 2.4 JTD connection problem
Post by alpha »
I have the same problem
Connects to Airbag and ABS ECU's ok
but no engine ECU
I have notice the latency high warning in the bottom left of FES
All settings have been made as recommended at the website
@skylight75 proably has to select engine "Bosch EDC15 Diesel Injection (2.4)" which is for "ALFA 156 2.4 JTD"....
It is different than "156 '02 2.4 JTD 10V".
alpha
Post by alpha »
Hi Yani
Any ideas on my problem ?
As i said ok to connect to Airbag and ABS but not the ECU
Happy New Year :)
YorT
Post by YorT »
alpha wrote:Hi Yani
Happy New Year :)
I have the same problem connecting to 147 TS 2.0, After I scan, it lets me get body, CAN and other stuff, but ABS or ECU do not appear in the scan list and as a result gives me an error message that I am unable to connect.
alpha
Post by alpha »
Select your vehicle
Hit connect
And thats it it should work.
See my post regarding the driver issue.
viewtopic.php?f=5&t=1816
