For information i have tested today the software with full licence on my fiat coupe 20VT year 1998 to the ECU BOSCH MOTRONIC M2.10.4
I use KKL cable
The connection to the ecu work but maximum 45 seconds ????
I have tested configuration to the com port bauds,latency response ...... all parameters but always problem.......
connection to the ABS ECU =====> work perfectly !!!!!!
Connection to the airbac ecu ====> NOT WORK ???
I use the program to my alfa 156 jtd ====>>>> work perfectly
If you are more information for me ?????????
Sory for my english
Best regards from belgium
Patrick
FIAT COUPE 20V TURBO
Re: FIAT COUPE 20V TURBO
I Have the same problem. It shows latency too high and disconnecting. I've installed .net framework 3.5 and still have the problem! I use FES 2.6 Registrated .
What about the power profile? You should not use a power saving profile like Max Battery, Power Saver or whatever it is named because it will slow down your laptop.
Don't have problems with outher cars. I will check with anouther laptop and will post again!
Thanks.
Thanks.
