Fiat Panda 1.2 8v 2006 steering fault
Hi All. I am new to this forum. I had the free program for a while and worked good. I have a fiat Panda 1.2 8v 2006 model in just now with a steering light on. I upgraded to the full version to read this ecu. I have the ELM327 module 1.4 usb. Does this module read the ecu. I read somewhere you might have to do something with pin 9. Any help would be great. Thanks. Ian at L & N Diagnostics.
Re: Fiat Panda 1.2 8v 2006 steering fault
you are right! to read Delphi Electric Steering (servo) you need to modify your ELM cable!
i think you need to connect pin 7 and pin 9 to read electric steering!
See this page: http://www.multiecuscan.net/HowToUse.aspx
