airbag fault 01
wynand2000
airbag fault 01
Post by wynand2000 »
my 156 from 1998 1.6 TS his airbag light is burning and i can`t reset it. it says code 01 and that internal components in the ecu may cause this or lack of mass or + voltage.
i soldered the wire under the non-driverseat.
i checked all wiring and plugs
there was a loose plug near the airbagmodule(ecu) and that was an error 0B , but the nice thing was i could reset that one, so now there is only the above mentioned.
am i in need of a new module than?
please help
thanks and greetings,
Wynand
mattydr67
Re: airbag fault 01
Post by mattydr67 »
01 Airbag control unit
If all connection to your Airbag ECU are good then you have one choice: Change the ECU becase is damege.
I had same error on my wife's car and I didn't try to check anything. I just change the Airbag ECU and everythings it's working now.
If you have possibility to change the Airbag ECU without pay for it first will be the best for you. I had that chance and i didn't work to check all the connector or the wires.
So good luck
Re: airbag fault 01
i agree with mattydr67. it is probably the Airbag ECU!
wynand2000
Re: airbag fault 01
alfa156sarajevo wrote:i agree with mattydr67. it is probably the Airbag ECU!
that fixed it!!!!
thank you guys!
