I'm a new user to the program
I have FES v2.4 using a VagCom connection to a Bosch Motronic ME3.1 ecu
The program keeps disconnecting especially when I'm viewing the engine management, not so much
with the gearbox management.
I noticed the latency warning comes up as well
How can I prevent this from occuring as often as it does?
Regards
FES keeps disconnecting
Re: FES keeps disconnecting
I have the same problem,
V2.4.1
When i give the command "connect" its not a problem to make a connection
But when i click "parameters" he keeps disconnecting, sometimes he says Latency to high
I Already installed the older drivers and put the latency to "1"
I'm using an ELM interface too wich works good, but I bought a Vagcom KKL to modify and read out my ABS,Airbag and EPS
But before modifying it I just tried to test it.
I also experimented with lowering the Baudrate, but that doesn't work.
V2.4.1
Please check if you have any errors in body computer.
I suppose that you have CAN errors which means that you have problem with electric beam.
BAS
BAS
Update.
I find out that the problems of disconnecting only occurs when reading out the motor ECU.
When i am reading out ABS,EPS or Airbags the connection is stable.
For me its not a problem, because i'm using the Vagcom Cable only for reading out the ABS,EPS or Airbags.
For Motor, DASH, Body etc. i'm using my ELM
