Hello. I have a fiat bravo 1.6 16v Phase I 1AF.16 IAW ECU, I can not connect to the ECU with version 1.6 I would like to add this unit to see a bug I have.
Thanks a greeting.
New ECU
Re: New ECU
make sure You have set the latency timer to 1. I had same issue like You.
Go to device manager, COM ports, then to your COM assigned to cable and check the advanced settings. If You can't see latency timer, you should upgrade the driver from FTDI.
You need the cable connected to ECU, BAT+ and key must be in ON position.
Re: New ECU
This ECU it is not supported yet.
The www.ftdichip.com recomand to set lattency at 2 not at 1 for the new drivers.
Re: New ECU
Mine appears as BRAVO / BRAVA 1.6 16V, but no injection unit could be added for next version. Thanks a greeting.
Re: New ECU
IAW 18F 84 Palio 1.2 V8 I can not connect.
FTDI new driver.
FTDI new driver.
Re: New ECU
I haven't seen your ECU in the list.
It isn't covered yet that's why you cannot connect.
Good Luck
P.S. BTW ftdchip.com recomand to set lattency at 2 not at 1 for new drivers version.
Good Luck
Re: New ECU
How I can connect the BRAVO / BRAVA 1.6 16v? the injection unit does not appear. Will has come out in future versions of the program?
Greetings.
Greetings.
