Hi!
Is it possible to enable feature to open and close all 4 windows with remote key? Well my Alfa 159 can only pull down all four windows with remote but to close them i have to do it manualy (with remote i can not do this). Well i know that some model has this enabled but some don't because of safty risk. So is this possible to do with version 2.4 to enable this feature, now when body computer is supported?
(Alfa 159) Open and cloce windows with remote
Re: (Alfa 159) Open and cloce windows with remote
I don't have any info about enable/disable closing of the windows with remote control.
It could be a problem in the "Anti-Trap" sensors. Each door has ant-trap sensor on the top to detect presense of objects when windows go up. The automatic rising of the windows is disabled when any of the anti-trap sensors does not work (I've tested this on my stilo by disconnecting one of the sensors).
My advice is to connect to "Passenger door", "Driver's Door" and "Boot" ECUs and check for errors first.
Also, check the value "Anti-trap sensor" parameter for all doors. The voltage should change when you press up (with hand) the upper rubber seal of the window.
I have connected yesterday and there are no errors. I know that this was feature on some cars that was enabled and on other was not.
