I have elm327 and i try to use multiecuscan last version to reset my ecu on alfa 147 to remove "alert change oil".
To perform this operation i try to reset trouble code error and reset service, but this still doesn't resolve my alert problem.
How can i do to remove alert change oil?
reset "alert change oil"
Re: reset "alert change oil"
Your car has DPF right?
If that is true you will have to go to the Adjustments tab and there you will be able to find an oil interval reset that is related to DPF...
Great!
I didn't reset change oil DPF... now that i reset DPf and service it seems to work all perfect!!
Thanks again!!
Thanks again!!
Great!
I didn't reset change oil dpf in adjustment tab.... now that i reset dpf and service all seems to work perfect!
Thanks again!!
Thanks again!!
Hi. I have just carried out the first oil change, for me, on my 1.9 8v Croma. I have downloaded Multiecuscan and bought a USB KKL VAG-Com lead to be able to reset the Oil change function. Although my computer connects to the ECU and various functions work my computer does not display any Tabs above F6 so I can not reset the Oil Change. What am I doing wrong. All help appreciated. Thanks. Kadee.
Hi. I posted a question re Oil Service last week but it seems to have vanished into the ether, albeit I seem to remeber it stating something like an approval by the webmaster or the committee. My question was that I do not get the Adjustment Tab up on my screen to reset the Oil Service etc. on my Croma 1.9 8valve. Am I doing something wrong or was there a fault with the downloading of Multiecuscan. Any help or suggestions appreciated.
Kadee
Kadee
