Airbag Node (NAB/ORC): EOL Failed
ibelonginthekeys
Post by ibelonginthekeys »
When performing a proxi alignment on my 2024 Alfa Romeo Stelvio Q4, I am getting a timeout on the airbag module.
I have done the following troubleshooting/config steps so far:
  • Software: Updated to 5.3R1
  • Software: Interface set to ELM 327 HIGH SPEED and passes test
  • Software: Can connect to airbag module directly using grey adapter to read data
  • Software: Reset all codes in DTC scan and retry
  • Car: No weight on passenger seat
  • Car: No seatbelts buckled
  • Car: Disconnected battery and installed SGW
  • Port Settings: Set BPS to 115200
  • Port Settings: latency to 1
  • Port Settings: Set minimum timeout read/write to highest value
  • Performed full proxi alignment 5x times with no change in result, with key off for at least a minute after before restart
  • Diag: Captured PDF diagnostic report after latest attempt (attached), no apparent changes during any attempt
I am also getting all kinds of various warning lights and odometer flashing which I presume are due to the alignment not completing after module change, as they only happened after installing the SGW.
Any thoughts on what I am missing to get all the modules aligned? Thanks!
Report1.pdf
(473.44 KiB) Downloaded 553 times
shpuncik
Re: Airbag Node (NAB/ORC): EOL Failed
Post by shpuncik »
there was problem with proxi alignment on airbag node on MY23/MY24 models not sure if it was fixed. try contacting support for more information.
ibelonginthekeys
Thanks I went ahead and did so. I wasn't able to find any mention of that issue elsewhere, and the module is listed as supported on the Vehicle Support list and there are no asterisks or warnings listed so hopefully there is a fix pending.
Restraint/airbag management
Bosch Airbag
Supported functionality:
Read identification details, Read/clear error codes, Read error code details, Read up to 47 live data parameters
Possible to connect with following interfaces/adapters:
ELM 327/OBD Direct-Protect/Generic OBD+GRAY adapter A6
OBDLink SX/MX/MX+/LX+GRAY adapter A6
Vgate vLinker MC/MC+/BM/BM+/FD/FD+/FS+GRAY adapter A6
Vgate vLinker MS
CANtieCAR
chrener
Post by chrener »
Do proxi alignment with all seatbelts unlocked and with closed all doors...
shpuncik
Post by shpuncik »
btw, I have seen somewhere that using OBDLink cable instead of ELM327 proxi alignment was done successfully. haven't tried it myself for the moment.
SonofaBuick
Post by SonofaBuick »
Any news on this one? I have this same problem with my 2024. I haven't tried any other tools on it. I am using an iDiagnostic ELM interface from the UK on my U.S. spec 2024 Stelvio Ti Q4. I've used the iDiagnostics interface for many years without an issue.
Alkhanchi
Post by Alkhanchi »
Anyone was able to fix this issue? I ran into the same problem on my 2024 Stelvio competizione. Switching to race mode will trigger a check engine and start stop error, and the dna dial will default to n. I am using version 5.4
