Screwed my Fiat 500L
Koplinjp
Re: Screwed my Fiat 500L
Post by Koplinjp »
With no no year. I did not upload proxy bytes. I just seletect Multimedia GPS Module (change to enable) and Multimedia Aux input (also changed to enable). Did a proxy alignment and after that it worked!
Since aux Port was disabled, maybe that was the problem?
Problem solved! Couldn’t done it without your help… 👍
abarthmultijet
Post by abarthmultijet »
Great. No problem. Good luck
PedjaZ
Post by PedjaZ »
It would be nice if you could now give an insight into what the new proxy looks like so we could compare what has changed.
Koplinjp
Post by Koplinjp »
abarthmultijet wrote: 15 Feb 2025, 16:12 Great. No problem. Good luck
Hello (again). Is it possible that i messed up my DPF?
I did not see the DPF symbol on dashboard for a long time now.
The car seems normal, but is it possible that with this “problem” i disabled the DPF or something?
