Alfa Romeo Giulietta
Out of curiosity, I was doing a test reprogramming keys and remotes using the Multiecuscan utility. One of the keys, the one with the remote, hasn't opened or closed the doors for a while. I followed the steps up to the point where it asked me to insert key 2. I aborted the operation, and the program exited the programming screen. After that, the key no longer starts the engine. What I didn't do was unplug the OBD or wait the 60 seconds indicated in the instructions. Luckily, the key without the remote, which I didn't have at the time, still starts the car. In the parameters section, I see that I still have two keys enabled, but the remote key has a valid transponder, but the electronic key code is invalid.
What can I do now?
Should I try reprogramming again, this time with both keys and following the steps to the end, or can that key with the remote no longer be recovered? I'm afraid of leaving the car immobilized if something goes wrong.
Can anyone help me?
Giulietta key fob program failure
Giulietta 2.0 jtdm Distintive, Exeo 1.8 TSI, Mitsubishi Colt CJ
Re: key fob program failure
If you read the instructions right you need all the keys when doing programming.
Here are the instructions at the info menu:
This procedure allows the programming of keys/transponders in the Body Computer. The keys/transponders have to be pre-programmed with body computer's secret codes in order to be recognized by the vehicle. Follow the instructions on screen and make sure you have ALL keys (up to 8) before starting the procedure.
WARNING: DO NOT RUN this procedure if you don't know what you are doing as this procedure may permanently disable your keys! Make sure YOU HAVE ALL KEYS as you will have to program ALL of them into the Body Computer.
WARNING: You will also need to enter the electronic key code of your vehicle in order to execute this function. You can find this code on your vehicle's CODE CARD. Please be careful and note that the Body Computer will block itself for 30 minutes after an incorrect code is entered 3 times.
NOTE: You may run this procedure in simulation mode to see how it works. Basically, you have to do the following:
1. Start the procedure
2. The system will ask you to insert KEY 1 and click Y. After that the system will confirm if the recognition of the key is successfull.
3. The system will ask you to insert KEY 2. So, you have to remove KEY 1 and insert KEY 2. This procedure can be repeated for up to 8 keys.
4. The system will finally store all recognized keys into the body computer and will display a status of the whole procedure. You will still have a chance to abort the procedure before step 4 and restore the key data. However, after step 4 the new keys will be stored permanently and ANY existing keys that are not inserted/recognized during the procedure will be PERMANENTLY disabled in the body computer and it will not be possible to use them anymore.
ALSO NOTE: The vehicle will probably display immobilizer/key errors on the dashboard during the procedure! This is normal!
After the procedure:
1. Remove all keys, disconnect the OBD cable and wait 60 seconds
2. Take one key and start the engine with it
3. Turn off the engine and remove key
4. Close all doors and test the remote control (if this is an RF key).
Repeat steps 2, 3 and 4 for all keys!
So you advise me to start over and follow the instructions to the end? Can I get that key back?
Yes, I think if you start over with all the keys, you can bring them back.
Not a lot of experience with key programming, but some.
Thanks for your help.
Is there any forum member who has good experience reprogramming keys with Multiecuscan or Alfaobd?
I also have a new key from Aliexpress waiting to be added to the body, and I'm worried something might go wrong.
I've searched the forum and other forums, and there isn't much specific information on key reprogramming. Many have asked, but no one has reported doing it without problems.
Re: Giulietta key fob program failure
I try again, and the two keys are back, everything went well, I still need to reprogram them along with a new key...
I did it at the door of the Alfa dealership hehe
