FIAT500cRIVA.
I replaced Uconnect7 with a main unit that can use Apple CarPlay.
After doing proxy alignment, the ODO meter stopped blinking, but carplay became unusable.
Please tell me a proxy that can use CarPlay.
Current proxy.
33 32 31 35 30 30 33 34 36 33
37 4F 55 54 50 55 54 44 4A 49
54 20 17 11 09 4F 80 00 05 14
00 00 00 09 00 00 04 10 00 00
00 03 C7 77 06 DB 00 1C C0 00
00 00 16 00 01 08 94 06 41 01
00 40 00 81 20 75 41 0A 0C 0D
01 80 2E 24 00 00 00 00 31 05
61 03 00 00 04 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 06 00 94 00
22 00 04 88 02 00 20 80 00 00
40 00 11 00 0F 00 00 00 00 01
80 40 11 00 00 00 00 00 00 00
00 00 00 00 00 00 00 05 00 00
00 00 00 00 00 00 01 00 00 01
00 00 00
Kind regards
fiat500 apple carplay cannot be used
abarthmultijet
Re: fiat500 apple carplay cannot be used
Should be ok, you know how to perform an proxy alignment?
good morning
I'll try proxy alignment again.
I set the vehicle's country from Italy to Japan before replacing the display, will this have any effect?
Thank you for your understanding.
I performed proxy alignment again, but there was no change and carplay could not be used. It becomes an iPod. Originally, Carplay was used.
- IMG_7966.jpg (30.19 KiB) Viewed 25320 times
abarthmultijet
Don't think it has much effect, but can you try to put country to Netherlands?
I tried changing the country to the Netherlands on Uconnect7, but appleCARPLAY does not start and cannot be used.
Is there anything else to try?
Kind regards
Hello. I installed PLOXY, which you told me about in the previous 500, and fixed the error, and now I can use carplay. Sorry for the trouble.
Kind regards
- IMG_8119.JPG (4.29 MiB) Viewed 23281 times
- IMG_8117.jpg (98.92 KiB) Viewed 23291 times
- IMG_8116.jpg (85.87 KiB) Viewed 23291 times
abarthmultijet
Did putting it to Netherlands fix the carplay? Or did you not perform proxy the right way?
