Hello Yani,
I asked a couple of months ago if the Lancia Musa 1.9 jtd will be supported and wich type of ecm this car is using. Could you please tell me?
Allso I wanted to know wich ecu a Panda 100hp is using and if that will be supported.
Thank you.
Pascal.
2 Requests
Re: 2 Requests
Lancia MUSA 1.9JTD uses one of these 2 engine ECUs:
- Bosch EDC16C9 CF3
- Bosch EDC16C9 CF4
These EDC16 ECUs that are installed in MUSA are (for some reason) different that the EDC16 ECUs installed in the rest of Fial/Alfa/Lancia vehicles.
I will probably add support for them in future versions, but until then you can try to connect using EDC16 of some other vehicle (like Stilo 1.9JTD16V for example). I'm not sure if parameter reading will be correct in this case, but at least the error codes should be decoded properly.
I don't know about the Panda. Can you give more info about it.
- Bosch EDC16C9 CF3
- Bosch EDC16C9 CF4
