Hi!
Lancia delta xenon headlight, when will it be available with the MES?
Lancia delta xenon
Re: Lancia delta xenon
What year and engine? What do you want to do with Xenon? Read faults? Retrofitting?
1.9 multijet, 2012. The right front light had to be replaced and the leveling of the system should be adjusted. Leveling is not active.abarthmultijet wrote: ↑23 Oct 2024, 19:08 What year and engine? What do you want to do with Xenon? Read faults? Retrofitting?
I can't seem to find a special tab for the xenon. But I think you can fix the problem with MultiEcuScan. Program is designed for this kind of problems.
Unfortunately, if there is no xenon part in the multiecuscan, it cannot be solved. It requires an examiner.abarthmultijet wrote: ↑29 Oct 2024, 17:54 I can't seem to find a special tab for the xenon. But I think you can fix the problem with MultiEcuScan. Program is designed for this kind of problems.
