Hi everyone,
I own a Fiat Tipo 1.4 from 2019, and recently I upgraded the VP1 system from 2019 to VP2 2021. Since the upgrade, I've encountered a persistent issue with the odometer blinking, and I'm at a loss for how to resolve it.
I've tried several solutions using proxy alignment, but nothing seems to work. Here's a summary of what I've done so far:
- Attempted both unregistering and re-registering the system.
- Extended the byte configuration to 235 and 250 bytes.
- Changed byte 111 to 02.
Despite these efforts, the odometer continues to blink. I've attached a log file detailing the process and current configuration.
Can anyone help me stop the odometer from blinking based on this log file? I'm really stuck and would appreciate any guidance or advice.
Thanks in advance!
33 36 33 35 36 30 35 32 31 39 39 4F 55 54 50 55 54 44 4A 49 54 20 18 09 29 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 40 69 04 01 A4 10 07 87 A0 29 07 07 42 10 00 03 A3 1E 00 01 01 35 63 14 00 4F 03 34 00 83 08 00 1F 00 02 00 80 00 00 00 00 00 30 81 00 25 01 5A 00 07 00 A5 00 41 00 01 A1 17 00 40 00 01 00 C0 00 81 00 12 00 00 49 00 01 14 50 42 00 00 00 01 00 00 70 00 02 1C C0 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
Help Needed: Fiat Tipo 1.4 2019 VP1 to VP2 2021 Upgrade - Odometer Blinking Issue
Re: Help Needed: Fiat Tipo 1.4 2019 VP1 to VP2 2021 Upgrade - Odometer Blinking Issue
Try this:
33 36 33 35 36 30 35 32 31 39 39 4F 55 54 50 55 54 44 4A 49 54 20 18 09 29 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 40 69 04 01 A4 10 07 87 A0 29 07 07 42 10 00 03 A3 1E 00 01 01 35 63 14 00 4F 03 34 00 83 08 00 1F 00 02 00 80 00 00 00 00 00 30 81 00 25 01 5A 00 07 00 A5 00 41 00 01 A1 17 00 40 00 01 00 44 00 81 00 12 00 00 49 00 01 14 50 42 00 00 00 01 00 00 70 00 02 1C C0 00 80 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
Thanks for the quick reply. I will try and report tomorrow.
That is ok, let me know please
I tried it today, no changes. Mileage continues to flash, airbag also error in proxy "Request...". Do you have any other ideas?
Do you have more ideas?
Can you give me the list of error codes?
There is only one error code with the proxy, and that is an Airbag EOL fault at the node, and in the onboard computer, the error code B10AA-4Aabarthmultijet wrote: ↑12 Aug 2024, 19:57Can you give me the list of error codes?
