Proxy Aligment Fail on EMCM Tipo 2022
wpiotrek
Post by wpiotrek »
Hi, I'm trying to make Proxy Aligment procedure in Tipo after adding PAM module - all the time ETM and EMCM fail with timeouts. ETM anyway seems to work because radio is resetting afetr writting coniguration and are not listed with proxy errors. The problem seems to be with EMCM which shows error on module list. I'm using MES4.5, ELM327 on USB.
Could someone advise what to check / to do?
Odczyt danych konfiguracyjnych CAN ...
CAN CONFIGURATION DATA:
4F 04 20 C5 10 02 18 02 02 00 00 00 80 00 00 00 4F 04 20 C5 10 02 18 02 02 00 00 00 80 00 00 00 01 00 00 41 10 00 00 02 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F 04 20 C5 10 02 18 02 02 00 00 00 80 00 00 00 4F 04 20 45 10 00 18 02 02 00 00 00 80 00 00 00 4F 04 20 C5 10 02 18 02 02 00 00 00 80 00 00 00 4F 04 20 45 10 00 18 02 02 00 00 00 80 00 00 00 4F 04 20 45 10 00 18 02 02 00 00 00 00 00 00 00
33 36 33 35 36 32 32 32 33 35 36 4F 55 54 50 55 54 44 4A 49 54 20 22 05 16 4F 04 20 C5 10 02 18 02 02 00 00 00 80 00 00 00 4F 04 20 45 10 00 18 02 02 00 00 00 80 00 00 00 51 F9 0D 32 A4 95 07 E9 30 29 27 07 40 10 31 03 93 28 00 A2 01 35 73 14 01 4F 03 34 1B 83 08 00 33 00 05 00 A0 00 00 00 00 00 10 A1 00 25 00 5A 00 9D 06 8D 00 53 00 01 A1 17 00 40 00 01 00 C3 00 15 02 15 4A 00 49 01 01 34 11 72 00 00 00 01 00 00 F0 00 09 29 C1 11 80 38 04 01 00 00 00 00 00 00 00 01 07 C0 41 00 00 00 00 00 22 02 05 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Komputer nadwozia (BCM/NBC)
Węzeł sterowania silnika (ECM/NCM)
Węzeł wspomagania elektrycznego (EPS/NGE)
Deska rozdzielcza (IPC/NQS)
Węzeł układu hamulcowego (ABS/BSM/NFR)
Węzeł blokady kierownicy (NBS)
Węzeł czujnika parkowania (PAM/NSP)
Węzeł poduszek powietrznych (NAB/ORC)
Węzeł kontroli pasa jezdni (HALF)
Driver Assistant System Node (DASM)
Radio Frequency Hub Node (RFHM)
Węzeł klimatyzacji (HVAC/NCL)
Węzeł rozrywkowo-telematyczny (ETM)
Rear Right Climate Control Node (RRCM)
Left Blind Spot Sensor Node (LBSS)
Right Blind Spot Sensor Node (RBSS)
Entertainment multimedia control module (EMCM)
(Multiecuscan 4.5)
2024-02-19 17:30:05
Fiat Tipo 2015 1.6 Multijet 16V
CAN Setup / PROXI Alignment Procedure (356)
Komputer nadwozia (BCM/NBC): EOL Ok
Węzeł sterowania silnika (ECM/NCM): EOL Ok
Węzeł wspomagania elektrycznego (EPS/NGE): EOL Ok
Deska rozdzielcza (IPC/NQS): EOL Ok
Węzeł układu hamulcowego (ABS/BSM/NFR): EOL Ok
Węzeł blokady kierownicy (NBS): EOL Ok
Węzeł czujnika parkowania (PAM/NSP): EOL Ok
Węzeł poduszek powietrznych (NAB/ORC): EOL Ok
Węzeł kontroli pasa jezdni (HALF): EOL Ok
Driver Assistant System Node (DASM): EOL Ok
Radio Frequency Hub Node (RFHM): EOL Ok
Węzeł klimatyzacji (HVAC/NCL): EOL Ok
Węzeł rozrywkowo-telematyczny (ETM): EOL Ok
Rear Right Climate Control Node (RRCM): Ok
Left Blind Spot Sensor Node (LBSS): EOL Ok
Right Blind Spot Sensor Node (RBSS): EOL Ok
Entertainment multimedia control module (EMCM): EOL Nieudane
AKTYWOWANIE REGULACJI...
PROCEDURA 'OSIOWANIA' PROXI
Zapis danych konfiguracyjnych CAN ...
Zapis do modułu: Komputer nadwozia (BCM/NBC) UDANY!
Zapis do modułu: Węzeł sterowania silnika (ECM/NCM) UDANY!
Zapis do modułu: Węzeł wspomagania elektrycznego (EPS/NGE) UDANY!
Zapis do modułu: Deska rozdzielcza (IPC/NQS) UDANY!
Zapis do modułu: Węzeł układu hamulcowego (ABS/BSM/NFR) UDANY!
Zapis do modułu: Węzeł blokady kierownicy (NBS) UDANY!
Zapis do modułu: Węzeł czujnika parkowania (PAM/NSP) UDANY!
Zapis do modułu: Węzeł poduszek powietrznych (NAB/ORC) UDANY!
Zapis do modułu: Węzeł kontroli pasa jezdni (HALF) UDANY!
Zapis do modułu: Driver Assistant System Node (DASM) UDANY!
Zapis do modułu: Radio Frequency Hub Node (RFHM) UDANY!
Zapis do modułu: Węzeł klimatyzacji (HVAC/NCL) UDANY!
Zapis do modułu: Węzeł rozrywkowo-telematyczny (ETM) NIEUDANY! - Przekroczony limit czasu
Zapis do modułu: Left Blind Spot Sensor Node (LBSS) UDANY!
Zapis do modułu: Right Blind Spot Sensor Node (RBSS) UDANY!
Zapis do modułu: Entertainment multimedia control module (EMCM) NIEUDANY! - Przekroczony limit czasu
WYKONANIE NIEUDANE
chrener
Re: Proxy Aligment Fail on EMCM Tipo 2022
Post by chrener »
Update your MES version with newest one, because yours doesnt recognise ISO of Tipo22 radio unit...
wpiotrek
Post by wpiotrek »
Hi, thanks for advise, I did it yesterday - it works little bit better because ETM module saved conig correctly but EMCM still fail. In scan there are many of ECU unsupported.
Proxi procedure:
4F 04 20 C5 10 02 18 02 02 00 00 00 80 00 00 00 4F 04 20 C5 10 02 18 02 02 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F 04 20 C5 10 02 18 02 02 00 00 00 80 00 00 00 4F 04 20 45 10 00 18 02 02 00 00 00 80 00 00 00 4F 04 20 C5 10 02 18 02 02 00 00 00 80 00 00 00 4F 04 20 45 10 00 18 02 02 00 00 00 80 00 00 00 4D 04 20 45 10 00 18 02 02 00 00 00 00 00 00 00
33 36 33 35 36 32 35 39 33 37 32 4F 55 54 50 55 54 44 4A 49 54 20 22 05 16 4F 04 20 C5 10 02 18 02 02 00 00 00 80 00 00 00 4F 04 20 45 10 00 18 02 02 00 00 00 80 00 00 00 53 F9 0D 32 A4 95 07 E9 30 29 27 07 40 10 31 03 93 28 00 A2 01 35 73 14 01 4F 03 34 1B 83 08 00 33 00 05 00 A0 00 00 00 00 00 10 A1 00 25 00 5A 00 9D 06 8D 00 53 00 01 A1 17 00 40 00 01 00 C3 00 15 02 15 4A 00 49 01 01 34 11 72 00 00 00 01 00 00 F0 00 09 29 C1 11 80 38 04 01 00 00 00 00 00 00 00 01 07 C0 41 00 00 00 00 00 22 02 05 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Display Screen Module (DSM)
(Multiecuscan 5.2)
2024-02-21 21:27:56
Węzeł sterowania silnika (ECM/NCM): EOL Nieudane
Display Screen Module (DSM): Ok
Zapis do modułu: Węzeł rozrywkowo-telematyczny (ETM) UDANY!
WYKONANIE NIEUDANE
wpiotrek
Post by wpiotrek »
I've received patched version of MES 2.5R1 from Yanislav - it is working fine!
yhackup
Post by yhackup »
wpiotrek wrote: 29 Feb 2024, 19:38 I've received patched version of MES 2.5R1 from Yanislav - it is working fine!
Is there tipo in version 2.5? How did you do resolve? I have the same problem
wpiotrek
Post by wpiotrek »
Tipo is supoorted by version 2,5, but there was described problem. It is fixed in special version, you can download it here:
https://www.multiecuscan.net/SetupMultiecuscan52R1.msi - I received that link from Yanislav Karagyozov directly.
yhackup
Post by yhackup »
wpiotrek wrote: 06 Jun 2024, 16:47 Hi,
I will try it today, I hope my problem will be solved too.
http://forum.multiecuscan.net/viewtopic.php?f=6&t=10117
wpiotrek
Post by wpiotrek »
Hi, try and let know about the result. If it doesn't work for you - please just write on MES support email. Add application logs to your support case, I believe Yanisalv will help you to.
