HI.
I have Fiat doblo 263 2019 without radio.
I install the radio uconnect 5 FIAT 263 FL VP2 ECE DAB NAV works perfectly but i have the flashing Mileage as normal the proxy does not work comes up with added / error so the mileage still flashes. So I carry out an alignment, but it keeps failing the error I get is Entertainment Added/EOL failed .
here is my config CUSTOM PROXI
33 36 32 36 33 31 34 32 39 30 33 4F 55 54 50 55 54 44 4A 49 54 20 15 06 11 4B 10 00 04 11 00 00 00 09 00 00 04 11 00 00 00 85 C0 73 07 7B 00 00 30 A0 00 00 56 00 0F 00 00 06 0B 02 46 C0 8A 50 08 09 10 05 0C 09 00 80 00 00 00 00 00 00 54 02 44 01 00 11 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 87 00 94 00 00 00 00 82 12 37 00 00 00 00 30 00 00 00 00 00 00 00 00 01
Best regards.
Uconnect 5 Poxy alignment doblo 2019
Re: Uconnect 5 Poxy alignment doblo 2019
HI!
Upload this proxi setting
33 36 32 36 33 31 34 32 39 30 33 4F 55 54 50 55 54 44 4A 49 54 20 15 06 11 4B 10 00 04 11 00 00 00 09 00 00 04 11 00 00 00 85 C0 73 07 7B 00 00 30 A0 00 00 56 00 0F 00 00 06 0B 02 46 C0 8A 50 08 09 10 05 0C 09 00 80 00 00 00 00 00 00 54 02 44 01 00 11 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 87 00 94 00 00 00 00 82 12 37 00 00 00 00 34 00 15 00 00 00 00 00 00 01
You find the solution here-maybe You can help on this? Thank Youchrener wrote: ↑02 Jun 2023, 09:49 HI!
http://forum.multiecuscan.net/viewtopic.php?f=5&t=9907&p=27246&hilit=Vp2+convertion#p27246
