Is it right to write the registered keycode after each Multiscan restart in the keycodefield below?
Greetings
Registered Keycode
Re: Registered Keycode
If you are referring to the MES Software *License Key* the this only has to be done once.
Yes the registered MES.
I have to write it after each start...
Can i find it in any file?
If you are having to re-enter every run then this suggests to me that where you have installed MES does not possibly have write privileges.
I have no knowledge / idea as to where MES stores (and protects) the hardware and license keys.
Try re-installing MES.
If this does not work then contact MES Support. NOTE! supply purchase and registration information to help MES identify you as a valid user!
