I have an Australian spec 2017 Abarth 595 that used to have a UConnect5" PN:07356556170 and I just got a UConnect7" from an Australian spec 2021 Abarth 595 PN: 07357358580.
Before pulling the 7" from the donor car I confirmed all was working fine (including Apple CarPlay).
Once installed in my 2017, it powered up and I entered the unlock code and it works fine (but no CarPlay and the odo is flashing).
Tried a prox alignment and it failed with Request Out of Range. I'm a bit of a newbie to MES but have done this sort of thing before on VWs.
Here is the log:
CAN CONFIGURATION DATA:
4F 84 00 05 02 00 00 00 4F 84 00 05 10 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
4F 84 00 05 02 00 00 00 09 00 00 04 02 00 00 00 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 09 00 00 04 00 00 00 00
33 32 31 35 30 30 32 39 32 39 33 4F 55 54 50 55 54 44 4A 49 54 20 17 05 29 4F 84 00 05 02 00 00 00 09 00 00 04 02 00 00 00 91 C2 75 06 FE 40 1C C0 00 00 00 16 00 01 00 95 06 00 01 00 40 00 00 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00 94 08 52 00 04 88 00 00 20 00 00 00 40 00 01 00 0F 00 00 00 80 05 00 E0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Side Acceleration / Yaw Node (NYL)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
Convergence Telematic Node (CTM)
(Multiecuscan 5.1)
22/07/2023 20:01:07
Fiat 500 1.4 Turbo 16V T-Jet/MultiAir Abarth
Climate Control Node (HVAC/NCL): Ok
Side Acceleration / Yaw Node (NYL): Ok
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): EOL Ok
Convergence Telematic Node (CTM): Removed
Entertainment Telematic Node (ETM): Added / EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Request out of range error
[102A] errors: Byte 148: 00->1C
FAILED TO EXECUTE
ETM Request out of range error (UConnect 7" Upgrade) - SOLVED
Re: ETM Request out of range error (UConnect 7" Upgrade)
Ok, so I was perusing the forums and this custom set stops the ODO flashing, BUT the Carplay is still not working
33 32 31 35 30 30 32 39 32 39 33 4F 55 54 50 55 54 44 4A 49 54 20 17 05 29 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 91 C2 75 06 FE 40 1C C0 00 00 00 16 00 01 00 95 06 00 01 00 40 00 00 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00 94 08 52 00 04 88 02 00 20 00 00 00 40 00 95 00 0F 00 00 00 80 05 00 E0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I have the USB+LineIN External Media Port (Type 2) is that compatible?
Also, just dropping it here because not obvious from the user interface, to get to custom proxy window you need to hit CTR-ALT-C (or CTR-OPT-C on the Mac running Parallels) to get to that window. They really should have that part more clearly documented.
Re: ETM Request out of range error (UConnect 7" Upgrade) - SOLVED
So after all that headache, the problem with the CarPlay was the cable. When I tested my cable on the donor car (with 2 USB ports in the center console) it worked fine. On my car with the AUX+USB center console that cable didn't work. With an official Apple cable it works fine.
I also wrote up my whole process with pics here: https://www.vk2.net/articles/Abarth-UConnect%205-to-7-Upgrade
