2014 Fiat Punto Evo
indeuro
2014 Fiat Punto Evo
Post by indeuro »
ZFA19900000996089
During connection to 1) BSI and 2 ABS and I assume some other modules I keep getting ask to connect yellow connector I think, Maybe Red, cant remember, Anyways, everything works ok. This is a replacement CanTieCar interface, I,m having a hassel getting it loaded properly so I assume it not loaded. I can read and do necessary adjustments to the Selespeed unit, that works a dream. What have I done or doing wrong.
Re: 2014 Fiat Punto Evo
Post by s130 »
With a CanTieCar interface you should not need any adapter cables if your firmware is up to date. Check your firmware version and check the CanTieCar website.
NOTE! I have never used a CanTieCar interface. I'm just recollecting a post I saw some time ago about new firmware level.
shpuncik
Post by shpuncik »
there is check box in MES settings which prompts for adapters.
abarthmultijet
Post by abarthmultijet »
The CanTieCar interface does not need adapters
