Fiat Multipla 1.9 jtdm 2008 - will it works with FES ?
luks
Post by luks »
This car is with DPF and i would like to reset "service" after change oil.
rubberfingers
Re: Fiat Multipla 1.9 jtdm 2008 - will it works with FES ?
Post by rubberfingers »
Has anyone confirmed if this works or not? Also have a multijet Multipla 2007 and want to reset the oil change counter
thanks
rubberfingers
I ihave connected to my ECU using verion 2.1 and can see the oil change parameters etc. I have not yet done the oil change but I hope I can reset the counter
luks
Post by luks »
Where do you see oil change reset ?
i can't find this option.
Do you use VAG or ELM ?
Can you write parameters of your connection ?
