Hi all,
Currently in the process of acquiring the MES cables from Gendan to connect to the car.
I've seen many guides but I feel that the hexadecimal dumps are different on different cars/models, if I was post the output here would someone be able to direct or help me in which values to change to enable Apple CarPlay? The unit is a DAB NAV from a newer Fiat and is installed in the car already, it required a radio code to unlock functionality (which we did) and everything runs smooth besides the features that are missing and the flashing mileage on the dashboard.. any help would be greatly appreciated
Fiat 500 2016 Proxi Alignment to unlock Apple CarPlay
Re: Fiat 500 2016 Proxi Alignment to unlock Apple CarPlay
hi , im not saying this will work for you but it did for me
change
byte 38 = 10 (prevent mileage flashing)
byte 121 = 44 (nav+audio)
byte 123 = D5 SOME SAY C5 but D5 worked for me (that`s if you have dab)
byte 157 = 01 (car play)
change
