Alfa Romeo 147 FL Sunroof
Nannor1985
Post by Nannor1985 »
Hi there. I have a 147 Fl Alfa Romeo (1.6 TS ECO). The body computer was replaced by the previous owner, since then the sunroof does not work. I can't activate it even in the proxy sorting, it can't be selected from the list. I checked with other models as well, the function works when Fiat is selected, the sunroof option can be selected. What do I need to do to make the setup work? Thanks in advance.
Nannor1985
Re: Alfa Romeo 147 FL Sunroof
I looked at Mes, and if I select Fiat, the sunroof is visible in the proxy arrangement, which could be adjusted. However, if Alfa Romeo is selected, it cannot be adjusted.
abarthmultijet
Post by abarthmultijet »
Did you save your original proxy code?
Nannor1985
abarthmultijet wrote: 14 Nov 2022, 17:18 Did you save your original proxy code?
Unfortunately, I can't save it. Could it be made to work just by changing the proxy code?
abarthmultijet
Probaly yes, what fiat do you select?
Nannor1985
abarthmultijet wrote: 15 Nov 2022, 19:00 Probaly yes, what fiat do you select?
I was looking at a Fiat Stilo with a 1.6 engine.
abarthmultijet
Sorry for late reply,
Go to the fiat stilo 1.6 and go to the proxy allignment tab, then to the adjustments section, press simultaneously control, alt and c.
Copy that code and paste it somewhere (windows note works the best for me). Then change in de adjustments section that the car has a sunroof. Save the code and paste it below the old code. Look up which byte changes (and in what number/letterd and then go to your own car on mes and change the same bytes and then do the proxy allignment
(English is not my main language)
Nannor1985
abarthmultijet wrote: 22 Nov 2022, 20:51 Sorry for late reply,
Thanks, I didn't know this keyboard combination. I read the code: 35 31 37 32 33 35 34 33 20 20 20 50 50 45 41 43 45 45 45 53 49 20 02 12 02 6B 07 00 00 09 07 00 00 20 00 00 82 06 00 This is the code of my car. Same code as sunroof fiat code. If I turn off the sunroof on the fiat, I get the following code: 35 31 37 32 33 35 34 33 20 20 20 50 50 45 41 43 45 45 45 53 49 20 02 12 02 6B 07 00 00 09 07 00 00 00 00 82 06 00
Is it possible that something else should be set in the proxy? unfortunately the roof still doesn't work.
abarthmultijet
I think that something else is wrong, maybe a differnt part number for the body computer? If it was replaced by the previous owner you would probably never know. If the car accepts the allignment and the speedo doesn't blink and the car has no fault codes I think that the computer is the wrong one or there must be a loose electrical connector.
Keep me posted
shpuncik
Post by shpuncik »
abarthmultijet might be right. check part number of your body ECU as looks like there were different versions for cars with and without sunroof.
