Ducato 2013 changed gearbox
Danko
Post by Danko »
I have a Ducato 2.3 130hp 6 speed manual with replaced gearbox. Now the cruise control does not work, but the system does not have errors. Cruise only works in 5th gear. In 2, 3, 4, 6th gear ecu does not see the gear selected, only when I put it into 5th gear ecu manages to calculate current gear and enables the cruise.
Is there a way to change the gearbox ratios in ecu memory?
p.s. I'm licenced MES user, but I might have posted in wrong room.
chrener
Re: Ducato 2013 changed gearbox
Post by chrener »
Did you changed your transmission with same part number?
Main problem is in different gears ratio or in ECU adaptations..
Try to reset self-learning function in ECU
Danko
Post by Danko »
I tried everything I was able to try with MES, but no help. I dont know what gearbox is fitted, I did not swap it, it came to me to solve the cruise not working problem.
shpuncik
Post by shpuncik »
drop VIN number. original gearbox was also 6 speed?
