Fiat 500 MP3 swap to VP2 proxy failed
I swaped the original radio MP3 for VP2 unit and I always get error with byte 115 after proxy.
It shifts me from 00 to 07 in byte 115 as you can see in error logs, there are 3 logs.
Primary and only problem is blinking mileage.
I have disconnected the blue&me module.
Am I missing some additional wiring for Uconnect5?
Thank you
https://mega.nz/file/GFw1SIhR#1W4SrTyIZlci5TTC-QORbLug3YmEVJb-DAwQqv1OR1w
Thank you
Re: Fiat 500 MP3 swap to VP2 proxy failed
Hi!
Byte 115 means AUX ports so you will need to check your USB housing and configured it correctly
Byte 115 = 01 AUX ; 02 AUX+USB ; 03 AUX+USB+SD ; 04 AUX+2xUSB
So try to set value 02
Byte 123=04 means DAB Enabled
Hi.
Thank you for clarifying that.
Did I understand correctly, I can't get it to work without a USB port wired to the player?
Probably yes.
But do you have USB port right?
You can connect it together via normal PC USB wire (from printer or something else)
Or add cheap universal usb female Port and connect to radio...
Then set byte 115 to 01
No usb, only AUX plug.
Tried byte 115 to 01, but now in error report it says 01>06, and after i changed it it reports 06>01...
Here are the errors in Uconnect5:
U0140-87 - Communication with Body Computer (BCM/NBC) Missing message Present
B157A-13 - DAB aerial Open circuit Present
B1577-13 - Universal Consumer Interface (UCI) Open circuit Present
B143A-13 - Microphone Open circuit Present
Here is the error in BCM:
B10AA-4A - PROXI configuration control Incorrect component installed Present
Here is the current proxy:
33 32 31 35 30 30 31 36 35 39 31 4F 55 54 50 55 54 44 4A 49 54 20 15 11 24 4F 84 00 04 02 00 00 00 09 00 00 04 02 00 00 00 81 C0 75 06 FE 00 1C 80 FA 90 00 16 00 01 00 84 06 01 01 00 00 00 00 30 79 41 0A 0C 0D 00 80 0E 23 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 02
Proxy completed ok with byte 115 -> 12 but mileage is still blinking
29-Sep-22 21:02:35
vehicle diagnostics software for italian cars
1 www.multiecuscan.net
CAN CONFIGURATION DATA:
4F 84 00 04 10 00 00 00 4F 84 00 04 10 00 00 00 08 00 00 04 10 00 00 00 08 00 00 00 10 004F 84 00 04 10 00 00 00 09 00 00 04 10 00 00 00 4F 84 00 04 10 00 00 00 09 00 00 04 10 0033 32 31 35 30 30 31 36 35 39 31 4F 55 54 50 55 54 44 4A 49 54 20 15 11 24
4F 84 00 04 10 00 00 00 09 00 00 04 10 00 00 00 81 C0 75 06 FE 00 1C 80 FA
00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 04 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Side Acceleration / Yaw Node (NYL)
Airbag Node (NAB/ORC)
(Multiecuscan 5.0)
29-Sep-22 21:02:31
Fiat 500 1.4 Turbo 16V T-Jet/MultiAir Abarth
Body Computer Node (BCM/NBC) EOL Ok
Engine Control Node (ECM/NCM) Ok
Electric Steering Node (EPS/NGE) Ok
Dashboard Node (IPC/NQS) EOL Ok
Brake System Node (ABS/BSM/NFR) Ok
Climate Control Node (HVAC/NCL) Ok
Side Acceleration / Yaw Node (NYL) Ok
Airbag Node (NAB/ORC) EOL Ok
Entertainment Telematic Node (ETM) EOL Ok
WARNING This vehicle is properly configured. PROXI Alignment is not needed!
How come proxy is not needed but mileage is blinking?
BCM error:
(Multiecuscan 5.0)
29-Sep-22 21:02:31
BCM error:
Only AUX is 115=01 but some cars need to add 10 with it so try to configure with 115=11maliomladinac wrote: ↑29 Sep 2022, 18:07 No usb, only AUX plug.
Please send a log from uconnect unit.maliomladinac wrote: ↑29 Sep 2022, 19:06 29-Sep-22 21:02:35
(Multiecuscan 5.0)
29-Sep-22 21:02:31
BCM error:
Did you connect every antenna correctly? Dab Antenna was retrofitted? Is microphone installed in car?
Speaker plug is not connected.
Everything else is missing at the moment. Need to rewire it from Blue&Me to Uconnect.
https://prikachi.net/image/LZaxFc
Can you explain how to get the log from uconnect?
Have you fixed this error? I have the same in my retrofitted uconnect 7 in 500X
Error code: B1577
Open circuit
Error code: B1577
Open circuit
