I connect to Body Chasis, Adjustment and press ALT CTRL C.
Windows opens a new window with a lot of bytes.
Anyone to know what is the meaning this bytes ? Exist any list to consult it ?
I know, for example, that byte 65, is for TFT Display, with this vaules:
00- Normal Display
20 - Sport Display
40- 500 Turbo Display
60 - Abarth Display
But i don't know what is the meaning of the other bytes.
Can you help me ?
Thank you,
BR.
00- Normal Display
20 - Sport Display
60 - Abarth Display
Can you help me ?
Thank you,
BR.
io sto cercando una soluzione per byte del manometro turbo sempre acceso.
nessuno può aiutarmi?
Uconnect 7 Fiat 500 Proxy Alingment
Hi guys, i have a Fiât 500 1.2 Club 2015 with TFT. i remove my Uconnect 5 for a 7.
My odometer flash so i try with the multiecuscan and i have an error « Entertainement Telematic Node ETM » EOL Failed.
What can i do. If somebody can help me
Many thanks
Many thanks
Hello MichL,
I have send you a private message.
Hi to all.
I retrofitted an Uconnect 5 Live DAB in a Lancia Ypsilon 2012.
The proxy allignment executed well after a lot of adjustement but my mileage are still blinking.
Someone can help me with the correct proxy configuration?
My current proxy is 157 bytes
33 32 34 30 32 30 30 32 39 36 35 4F 55 54 50 55 54 2D 4A 49 54 20 11 11 21 4F 00 00 04 10 00 00 00 09 00 00 04 10 00 00 00 03 80 73 06 E5 00 FF 00 A0 00 00 06 00 07 00 94 06 0D 01 3C 00 00 01 01 35 50 0A 5C 00 00 00 00 15 00 00 00 00 11 05 40 00 10 00 00 00 00 00 03 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B5 00 00 00 00 00 07 00 00 80 00 00 78 00 45 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
Thanks in advance.
Andrea
Thanks in advance.
Andrea
Many thanks.
I m from Paris.
@MitchL
Go to proxy allignment tab, (body-> can setup/ proxy allignment procedure (2014+)-> adjustments tab-> then press control alt c at the same time. You get a menu with a code. Send that code to this thread.
Hi Abarth,
Thanks for thé help, so the Numbers are
33 32 31 35 30 30 31 34 31 35 30 4F 55 54 50 55 54 44 4A 49 54 20 15 07 11 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 42 71 06 FE 20 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 18 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 93 02 00 20 80 00 00 44 00 D1 00 0F 00 00 00 00 01 00 E0 01
When i run multiecuscan to the Uconnect 7 i have thé message B157A-13-DAB aerial open circuit présent.
Do you have DAB aerial?
EDIT:
Iam sorry, i write again to you...
