Hello everybody.
I have a problem with my custom proxy for a Fiat 500e with retrofit uconnect7.
After 2 days of try and error almost everything is working.
No flashing milage.
My Uconnect 7 is radio with carplay. No Navi, No DAB.
But I can't enable Carplay.
I know this should be Byte157=01 Carplay
Also "eco Drive" function is missing. In one stage it was there. But I can't remember which byte I changed..
Can somebody help me?
Here is my current hex:
31 36 31 32 31 38 31 30 35 30 30 31 32 33 34 35 36 37 38 39 30 20 16 06 03 4D 84 40 05 13 00 02 00 09 00 00 00 13 00 00 00 80 D0 4D 06 F4 00 01 70 0A 01 00 67 00 09 00 94 00 00 04 00 01 A0 10 00 00 00 00 00 00 00 00 00 27 00 00 00 00 35 06 C1 01 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 90 18 52 30 00 D0 02 00 30 00 00 00 70 00 81 00 00 00 00 00 00 01 00 A0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Many Thanks in advance
Fiat500e Changed Uconnect5 to Uconnect7 proxy alignment questions
Re: Fiat500e Changed Uconnect5 to Uconnect7 proxy alignment questions
Done same in our 2017 500e
Most features are working now, if my Backup is right this should be last proxy:
31 37 31 36 38 32 34 35 35 30 30 31 32 33 34 35 36 37 38 39 30 20 17 07 10 4D 84 40 05 13 00 02 00 09 00 00 00 03 00 00 00 80 D0 4D 06 F4 40 01 70 0A 01 00 17 00 09 00 94 00 00 04 00 01 A0 10 00 00 00 00 00 00 00 00 00 27 00 08 00 00 35 06 C1 01 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 90 18 52 10 00 D0 02 00 30 00 00 01 74 00 D5 00 00 00 00 00 00 01 00 A0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 45 00 00 00 00 00 00 00 00 05 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
check log files, should be able to restore ECO mode from there
There was a mistake. I do not have Eco Mode since it is an 500e.
But still CarPlay is not working.
What do you think? Does my Unit has CarPlay or not?
On the back there is written: CONTINENTAL Fiat VP2 312 7in EMEA w/o CarPlay
However, I am not able to enable this function.
@Nirvananils your proxy is too long
No its not..... It's quite correct for our uConnect7 with Carplay activ and also some other tweaks. It was shorter in the beginning, but add some offset to activate most featuresFiat500e wrote: ↑01 Oct 2021, 09:05 There was a mistake. I do not have Eco Mode since it is an 500e.
