I've been working on an Alfa Romeo GT 2004 3.2. It has the SRS light illuminated.
On scanning the Airbag Module I get Code 1A - Airbag Control Light. I have followed the fault finding steps, +12V, grounds and lamp and all checks out ok. Is there anything else that could be causing this fault code?
Alfa Romeo SRS Code 1A - Airbag Control Light
Re: Alfa Romeo SRS Code 1A - Airbag Control Light
If i remember right the code 1A means that there is an internal failure in the Airbag ECU unit. The only way to delete the error is to reprogram the Airbag ecu eeprom. or get another Airbag ecu unit from anothere car with the same number as you have on your Airbag ecu unit.
