Uconnect reset during engine crank
davidino66
Post by davidino66 »
it is not a question directly related to multiecuscan, but inherent ... I installed a Uconnect 6.5 inch, on a Jeep Renegade that had a 5 inch. the problem is that while starting the engine, the unit resets itself, as if there is insufficient voltage. I know there is a VSM Voltage stability module that should avoid this problem ... Has anyone ever this? thank you
davidino66
Re: Uconnect reset during engine crank
problem solved: battery "border line"... replaced and problem gone
