I've started using 4.7 on my early 2017 Giulia Quadrifoglio.
Although Scan recognises both left and right Active Aerodynamic Modules, I can't get MES to connect to either of them. I tried several times.
Andy
MES 4.7 - Quadrifoglio Splitter
Re: MES 4.7 - Quadrifoglio Splitter
try this .... if you use elm327 when it asks you to insert adapter 5 do not insert it and go on
I'm seeing the same problem on my 2019 Giulia QF. No connection with or without adapter 5. I'm also not seeing a lot of other modules, only a very few show up with the adapter, and a few others without.
I wonder if adapter 6 is actually what's needed on this model?
Has anyone else tried?
I use MES Multiplex. I understand that a problem is recognised in 4.7 and there will be an update soon.
In which case, hurrah for updates.
Happy to contribute reports or testing if needed to help with any patches.
I see 4.7R1 is now released.
Downloading now.
This evening, my laptop, along with adapter 5, will go and have a little chat with those splitter modules, see if they're feeling more talkative now.
