i bought acable through the internet from this site
http://www.autotec-direct.com/usb-iso-k ... -428-p.asp
now as i connect it and make comm port to com2 as i set it
now when i press connect multiecuscan dosn't make the connection it say check com port or it's properties
now what to do ??? if there is any kind of data rate or any other values to be modified plz reply
help with this cable
Re: help with this cable
Cable that you bought is Ok!
Just have few questions:
Did you set up you com port settings in control panel?
Did you made modifications on your cable?
