On Fiat ducato 2019 someone by original front led lights. We tray to change classic light with led. After change led lights blinking during drive.
I have multiecuscaner version 4.3, we try to update proxy procedure. If I go to body computer there is not option at adjustments enable LED lights and also after proxy procedure.
IS there some other different step or this program dos not support such option?.
BR
Proxy Alignment
Re: Proxy Alignment
Or maybe someone knows if this is possible with newest version 4.61? I search on the internet, and I read there for this is needed to change proxy map in body computer wit those ho have inside parameter for LED lights. In which way this can be done?. I also try with alfaOBD program, the same without results.
Best regards
Best regards
