I have problem with out of range, does anyone have a byte definition for a 2012 panda car ?? especially those 66 and 72 bytes
Writing to module: Airbag Node (NAB/ORC) FAILED! - Request out of range error
[102A] errors: Byte 66: 3A->35 | Byte 72: 00->80
CAN CONFIGURATION DATA:
6F 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 4F 00 00 04 00 00 00 00 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 01 00 00 00 00 00 00 00
30 36 33 31 39 30 30 38 34 37 38 4F 55 54 50 55 54 44 4A 49 54 20 14 06 03 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 01 00 73 06 E5 00 00 00 00 00 00 06 00 07 00 04 06 15 01 1E 00 00 00 01 3A 41 0A 0C 0D 00 00 00 00 00 00 00 00 11 00 10 00 00 00 00 00 01 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Receiver Radio (NRR)
(Multiecuscan 4.6)
2020-03-29 15:30:43
Fiat Panda 2012 1.2 8V
Dashboard Node (IPC/NQS): EOL Failed
Receiver Radio (NRR): Ok
Airbag Node (NAB/ORC): EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
FAILED TO EXECUTE
Regards
