VAG KKL cable connections
Hello i have a problem to connect my alfa mito 1.4 tb multiair i dowloand the software and buy this https://www.amazon.it/gp/product/B01BFI ... UTF8&psc=1 .but the link beetwint car and pc doesn't start. i don't know what can i do.
Re: VAG KKL cable connections
The Alfa Mito ECU's/Nodes are all CAN Bus units. The KKL diagnostic cable you have will not work.
You need and ELM or OBDLink diagnostic cable.
See http://www.multiecuscan.net/SupportedVehiclesList.aspx
A word of personal experience: be wary of the entirely blue KKL cables. I got mine in the mail today, and the USB connector was some bootleg shit, and the contacts were recessed way too much into the phelonic white spacer thing, and one of the pins had broken in the connector. I had to do a transplant and solder in a new USB cable to the OBD side to make it work.
You make a valid point post regarding KKL / ELM / other devices available for use with MES. This is my personal view regarding MES and required hardware.svetunE wrote:A word of personal experience: be wary of the entirely blue KKL cables. I got mine in the mail today, and the USB connector was some bootleg shit, and the contacts were recessed way too much into the phelonic white spacer thing, and one of the pins had broken in the connector. I had to do a transplant and solder in a new USB cable to the OBD side to make it work.
MES is exceptional value for the money. In addition MES / Yani has taken the time and trouble to provide a list of recommended suppliers of MES and hardware that WILL work and if you have problems will provide support. Yes these recommended suppliers are not the cheapest, neither are they well over priced. What one gets is and all round, good value, hassle free solution which IMHO is crucial when it comes to vehicle diagnostics, especially when altering vehicle configurations and programming.
- Contact:
I bought a cheapie all blue cable from ebay seller "cube_tool"
So far its working great and uses the FT232R.
9.50 USD shipped.
9.50 USD shipped.
Salve a tutti, avete riscontrato problemi con cavo kkl su punto GT???
In pratica si collega in ECU ma dopo pochi secondi si disconnette....
- Contact:
Great Information was very useful for me..
Hi, kindly I have a Fiat Bravo 16 16v GT year 2000 103 bhp and I purchased a VAGKKL+ FIATECUSCAN blue 16 pin male connection connected to a USB with a switch on one side indicating pin 7 pin 3 pins 1/9 and pins 12/13 and on the other side a red led that didn't went on when connected, also a Fiat 3 pin connector to connect to the vehicle 3 pin connected to a female 16 pin with another two black and red crocodile connectors to connect to the battery terminals. With the package I received a disk and I followed all the instruction to test my vehicle for any errors, but it couldn't connect with the ecu so I searched on the forum and found out that others had same issues.
I made contact from where I purchased it and he told me to bridge pin 4 and 5 and I did but I am afraid to test it on the vehicle although pin 4 and 5 are both ground.
I checked the wires of the VAGKKL blue connection with the illustrations in this topic and it seems that they are connected properly.
kindly is there some one that passed through same experience that could assist me?
Thanks in advance
Thanks in advance
Xin chào, tôi cũng vừa mua cái kết nối VAGKKL +FIATECUSCAN, tôi đã cài đặt theo hướng dẫn, nhưng không kết nối với ecu, xe tôi Fiat siena 1.6 16v (palio 1.6 1.6v). Mong nhận được sự giúp đỡ các bạn
Do you mean the OLD FiatECUScan software or the MultiECUScan software?
The old FiatECUScan software did not support the Siena/Palio models as far as I can remember.
Ý bạn là phần mềm OLD FiatECUScan hay phần mềm MultiECUScan?
Phần mềm FiatECUScan cũ không hỗ trợ các mô hình Siena / Palio theo như tôi có thể nhớ.
