I've a Fiat Tipo 1.6 MJ 2016. I bought Stardiag OBD-USB adapter (like that which is on your website) and your software.
I've changed uconnect 3" with a uconnect 5" with Nav. I've added GPS antenna and now the Navigator works fine. I'v tried to do proxi alignment because Km blinks.
My original Proxi configuration is:
33 36 33 35 36 30 34 33 38 37 39 4F 55 54 50 55 54 44 4A 49 54 20 15 10 28 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 02 A4 10 07 8D D0 24 41 07 42 10 00 03 A3 28 00 02 01 35 43 14 00 01 00 00 00 03 08 00 11 00 00 00 A0 00 00 00 00 00 10 81 00 25 00 5A 00 64 06 AD 00 11 00 05 92 12 00 40 00 01 00 40 00 01 00 00 00 00 49 00 01 12 10 42 00 00 00 01 00 00 70 00 01 29 80 00 C0 00 00 00
when I try to do proxi alignment I have this Failure:
CAN CONFIGURATION DATA:
4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
33 36 33 35 36 30 33 30 31 30 31 4F 55 54 50 55 54 44 4A 49 54 20 15 10 28 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 02 A4 10 07 8D D0 24 41 07 42 10 00 03 A3 28 00 02 01 35 43 14 00 01 00 00 00 03 08 00 11 00 00 00 A0 00 00 00 00 00 10 91 00 25 00 5A 00 64 06 AD 00 11 00 05 92 12 00 40 00 01 00 40 00 01 00 00 00 00 49 00 01 12 10 42 00 00 00 01 00 00 70 00 01 29 80 00 C0 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
(Multiecuscan 4.4)
20/07/2019 10:59:02
Fiat Tipo 2015 1.6 Multijet 16V
CAN Setup / PROXI Alignment Procedure (356)
Engine Control Node (ECM/NCM): EOL Ok
Electric Steering Node (EPS/NGE): EOL Ok
Brake System Node (ABS/BSM/NFR): EOL Ok
Parking Sensor Node (PAM/NSP): EOL Ok
Airbag Node (NAB/ORC): EOL Failed
Climate Control Node (HVAC/NCL): EOL Failed
Entertainment Telematic Node (ETM): EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Engine Control Node (ECM/NCM) SUCCESS!
Writing to module: Electric Steering Node (EPS/NGE) SUCCESS!
Writing to module: Brake System Node (ABS/BSM/NFR) SUCCESS!
Writing to module: Parking Sensor Node (PAM/NSP) SUCCESS!
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Request out of range error
[102A] errors: Byte 123: 01->11
FAILED TO EXECUTE
I've changed byte 123 from 01 to 11 and I've added 00 bytes until proxi lenght is 235.
After to do this, Km blinks is fixed but the USB of the uconnet doesn't work. Usb drive come very hot. I've wrong somethings?
More, I would know if multiecuscan can:
1) change display mode (now my display show only Km, time and themperature) to show radio information or Navigator indication
2) change the function of "City" button in "Sport" like in https://forum.ecutuningperformance.com/topic/48800-modificare-configurazione-proxy/
3) when I try to connect Multiecuscan to Radio (Uconnect 5") or Clima using Yellow or Grey adapter I've an error
Fiat Tipo with USB disabled and other question
Re: Fiat Tipo with USB disabled and other question
To enable USB and AUX in Uconnect you must change this byte in proxi :
byte 115 - change to 10
byte 148 - change to 05
Ad2. Change city to sport you can in AlfaOBD --> body --> active diagnostic -> change configuration car > Advanced Driver Configuration Type Button change to Sport.
Ad3. TO clima you need blue adapter. MultiEcuScan 4.4 have bugs, look here : http://forum.multiecuscan.net/viewtopic.php?f=3&t=6767
Thank you, arturszymczak, for your anwers !!!!
I've tried your update, this is the result:
setting byte 115 to 10 USB work fine
setting byte 148 to 05 AUX work fine
using blue adapter I can connect to Clima
there's a way to connect to uconnect5?
