Fiat 500(l)/(X) Android auto
Hello guys , who have 500/500L/500X with Android Auto/Apple CarPlay , can they post their Proxy configuration?
Re: Fiat 500(l)/(X) Android auto
And I think it should be 7" Uconnect device.
Another point that should be discovered, are there any hardware differences between devices with and without AA/ACP.
buongiorno a tutti io ho 500x 4x4 ho comprato uconnect 7 ma non si allinea da errori durante allineamento proxy se qualcuno vorrebbe postare i bit con uconnect 7 grazie
bit originale con uconnect 6.5 = bit 153
33 38 33 33 34 30 32 37 37 34 30 4F 55 54 50 55 54 2D 53 49 54 20 16 03 15 4F 04 20 45 10 00 00 00 0A 00 00 00 00 00 00 00 4F 04 20 45 10 00 00 00 0A 00 00 00 00 00 00 00 D1 FA 0E 02 AC 82 07 E2 60 27 89 07 40 10 10 03 A3 28 64 92 01 35 73 14 01 4F 03 34 01 B3 A8 01 47 4B 07 00 A6 00 0E F9 00 00 10 01 00 05 13 54 91 64 02 AD 00 54 00 01 8A 15 3D 40 00 01 03 C5 00 D5 24 10 08 00 49 02 81 14 7B 42 80 00 00 9B AA 97 41 20 80 80 86 00
x chi legge in futuro con uconnect 7 nuovo allestimento bisogna allungare la proxy a 235 byte questo e il primo passo
I've read the proxi from another 500L with 7" Uconnect with Apple Carplay/Android Auto, Rear view camera and Parking Sensors:valerc wrote: ↑27 May 2019, 17:27yes, it must be 7", i think 98% of the devices share same hardware with and w/o AA, like the Tipo
33 31 33 33 30 30 34 31 32 34 36 4F 55 54 50 55 54 2D 53 49 54 20 17 11 15 4F 0C 00 05 10 00 00 00 09 04 00 05 10 00 00 00 A7 C7 71 07 85 00 37 00 30 A0 44 06 00 07 08 8C 03 15 01 28 C2 00 D1 02 35 41 0A 0C 0D 00 80 3E 58 00 02 00 00 43 20 29 03 08 11 16 00 86 20 05 05 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CB 00 01 08 0E 00 04 80 10 00 10 80 00 01 40 10 95 00 11 00 00 49 00 01 14 40 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
My 500L with 7" Uconnect with Rear view camera only:
33 31 33 33 30 30 34 38 36 35 36 4F 55 54 50 55 54 2D 53 49 54 20 17 11 15 4F 0C 00 04 10 00 00 00 09 04 00 04 10 00 00 00 A7 C7 71 07 85 00 37 00 30 20 44 06 00 07 08 8C 03 15 01 28 C2 00 D1 02 35 41 0A 0C 0D 00 80 3E 58 00 02 00 00 43 20 29 03 08 11 16 00 86 20 05 05 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CB 00 01 08 0E 00 04 80 10 00 10 00 00 01 40 00 85 00 11 00 00 49 00 01 14 40 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
It has 10 bytes which are different.
The ISO code, Hardware and Software numbers of Uconnect are the same.
For Fiat 500 (not X/L):
1. Hardware differs between CarPlay and non-CarPlay units. Carplay units have the GPS connector at the back and the GPS antenna is mounted in the car.
2. Proxi config differs (I am still trying to get mine to fully cooperate with me).
3. After changing the unit, the "new" one looses its VIN thus we end with no Uconnect LIVE features. This is solve-able by visiting the dealership and coding in the VIN of the car to the Uconnect unit.
If someone has full knowledge how to enable CarPlay and AA on a Fiat 500 with a changed Uconnect unit (I have moved from 7inch with no extras to a 7inch with CarPlay and AA + installed a GPS antenna under the dashboard).
My current proxi config is:
I have changed some bytes which were mentioned here. Because of some updates done to the car at the dealership I have now a 235 byte proxi config. For some reason CP is not working still.
Help?
Thanks!
33 32 31 35 30 30 33 35 36 33 34 4F 55 54 50 55 54 44 4A 49 54 20 17 12 15 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 C1 C7 73 06 F4 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 40 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9D 00 94 08 52 00 04 88 02 00 20 80 00 00 44 00 81 00 0F 00 00 00 00 01 00 C0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
Help?
Thanks!
On my fiat 500X I would like to replace my Uconnect 6.5'' by 7'', but I can not do proxy alignement. Entertainment Telematic Node (ETM) fail. Does anyone know how to configure proxy.
My proxy data :
33 38 33 33 34 30 30 33 32 36 31 4F 55 54 50 55 54 2D 53 49 54 20 15 05 19 4F 0C 60 45 10 00 18 02 0A 00 00 00 00
00 00 00 4F 0C 60 45 10 00 18 02 0A 00 00 00 00 00 00 00 D1 EA 4D 02 AC 82 07 E2 60 27 09 07 40 10 10 03 A3 28 64
92 01 35 73 14 01 4F 03 34 19 B3 A8 01 48 43 07 00 AA 02 10 EE 00 00 20 04 00 01 13 54 91 47 06 AD 00 42 00 01 8A
12 3D 40 00 01 03 C5 00 D5 44 10 08 00 49 02 81 12 7B 42 00 00 00 9B AA 97 41 20 80 00 85 00
Thanks in advance.
My proxy data :
Thanks in advance.
Try adding 00 until it reaches 235 bytes
33 38 33 33 34 31 32 35 31 30 36 4F 55 54 50 55 54 2D 53 49 54 20 19 05 10 4F 04 00 45 10 00 18 02 00 00 00 00 00 00 00 00 4F 04 00 45 10 00 18 02 00 00 00 00 00 00 00 00 D1 FA 04 02 AC 01 08 02 90 2E 09 07 42 10 00 01 A3 28 00 91 01 35 73 14 01 4F 03 34 19 A3 E8 00 58 03 07 00 A4 80 0E 96 00 00 08 21 00 25 11 54 EB 64 02 AD 00 52 00 05 8A 10 3D 40 10 03 03 C1 00 95 24 13 0A 00 49 00 81 14 5A 42 00 00 00 63 A2 99 71 20 80 AA C2 31 00 23 09 00 00 00 00 00 00 00 00 01 0C C0 01 03 42 00 00 00 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00---235 bit--------attivazione fai da te 4x4 cambio manuale kiles ita
ho un probbema le porte usb non vanno mes+alfaobd aiuto non posso fare aggiornamenti
I have completed to its reaches 235 bytes and Apply configuration below, the ETM it's now ok. But I have a trouble with automatic gearbox (TCM/NCA/NCR) EOL failed and gearbox doesn't works.
Do you have any idea?
Thanks in advance for your help.
Byte 115= 02
Byte 121= 40 Navi
Byte 121= 44 Navi+Audio
Byte 123= D5 Dab
Byte 130= 01 Fiat logo
Byte 130= 05 Abarth logo
Byte 148= 05 Uconnect 7
Carplay, Android:
Byte 157= 01 CarPlay
Byte 158= 00
Byte 159= 00
Byte 160= 01
Byte 115= 02
Byte 121= 40 Navi
Byte 123= D5 Dab
Carplay, Android:
Byte 158= 00
Byte 159= 00
Byte 160= 01
