I have MES 4.4.
Interface OBDLink MX WiFI and ELM327 USB (High Speed)
First problem :
ECU Uconnect Radio/NAV 5" - program prompt Adapter Yellow 3 - but i have this adapter and program won't connect with this ECU.
I have OBDLink MX WiFI and ELM327 USB (HIgh Speed) and with yellow adapter 3 can't connect with ECU.
OBD in Tipo use pins : 6, 14,3, 11.
Yellow Adapter use pins form vehicle side: 1, 9, 12
It is impossible for the yellow adapter 3 to connect with anything.
Second problem :
Another/Parking Control Bosch. - program prompt adapter 6 grey - but with this adapter can't connect with this ECU.
Grey Adapter 6 use pins form vehicle side: 12, 13
Similarly to the above, gray adapter 6 has no use in Tipo
But without adapter program connect successfull with Parking Control Boschin TIPO 2015 16V.
Third problem :
From MES 4.3 and MES 4.4 support OBDLink MX WIFI, but need blue adapter.
OBDLink don't need blue adapter, hi can automaticaly inside change the pins to connect with ecu propertly.
With automatic air conditioning using the OBDLink MX WIFI interface, I should connect without a blue adapter.
Best Regards
Artur Szymczak
