Hello!Manuvisentin wrote: ↑17 Apr 2019, 03:19alex-et3 wrote: ↑10 Nov 2018, 12:23noManuvisentin wrote: ↑10 Nov 2018, 11:40
And there’s a way to find the CAN packet that the Uconnect radio sends to the cluster to set the date and time and emulate it via a USBtoCAN with a pc?
Hi Alex! Now I bought a pre restyling cluster. I need to grt the %gas and gforce working. Those values travel through the CAN C Network. I tried connecting these options:
- C1 BCM connector pin 44 (can c +) and 45 (can c -) to pin 11 (c +) and 12 (c -) from cluster
- C4 BCM connector pin 25 (c +) and 27 (c -) to the cluster also and still not getting any value. Any tips?
My BCM part number: 51928686
My TFT part number: 735624426
Thanks!
Your problem is not the connections but the body computer is too old.
If you want to make the G forces work you absolutely have to change it, buying it new in fiat
