punto 1.2 8v petrol - ecu adaptiv reset
Scimitargte
did an adaptive reset as per instructions ie 'execute' followed by engine warm up and rev to 5500rpm holding it at these revs for 3 seconds - rrepeat 3 times but mil continues to flash, no faultt codes --- do I have to drive a few miles for it to relearn and switch off the mil??? help as mot due soon and not sure garage will test with a flashing mil although new regs say no test if mil is pernanently illuminated
Scimitargte
Re: punto 1.2 8v petrol - ecu adaptiv reset
Anyone, an Idea/suggestion?.
kido.resuri
Any fault codes stored?
The described method should work...
https://www.puntonium.hu
Scimitargte
Hi, no fault CODes done the execute then revved to 6k 3 times numerous times lamp will not extinguish
Scimitargte
as expected she failed her mot today due to the flashing mil. i have followed the guidance ie execute the command to run the reset and also the phonic wheel reset, revved her to 5.6k rpm 3 times letting it idle briefly before each rev up, switched off restarted and still flashes no faults found so now have a car i cannot use. Tried to find a way top force the mil to come on via the software thinking if i can turn it on and then off it may clear the flashing element - but there seems to be no way of doing this?
So I thought i'd try it again this time both tests state unable to run test conditions not 'right' or some such message.
please can anyway help me here???
kido.resuri
Did you experience any misbehaviour before you did the self adaptation and phonic wheel reset?
Try doing the resets again.
Are you using registered version of Multiecuscan?
Try contacting yani, he may ask you to send the report after the resets (the big red send report button in the main menu near the bottom logo).
Scimitargte
Car was and is running fine just thought I’d see what the reset did
I’ll mail Yani and hopefully he’ll have some solution
kido.resuri
Do you have the logs folder setup correctly? If so, try posting some logs about the reset.
ahmetefdal
plaese halpkido.resuri wrote: ↑24 Jan 2019, 18:23 Did you experience any misbehaviour before you did the self adaptation and phonic wheel reset?
hi.
I can't reset the phonic impeller. operation failed
punto 1 2 8v petrol ecu adaptiv reset
Thank you very much Max. Ive solved it. But not like your way. Tried it to install to D driver and now the problem doesnt occur. Ty again
