500L activate fog lamp with cornering function
Roberto0187
Post by Roberto0187 »
Good morning, I activated the fog lights feature in the fiat 500L body.
I noticed that the cornering function does not have menu settings.
I ask if this feature can be activated in the fiat 500L factory out of fog lights.
If you can activate this function you can explain how to do it.
Thank you
To do this I used a multiecuscan version 3.7 with elm 327 interface + adapter 2.
Roberto0187
Re: 500L activate fog lamp with cornering function
Good evening, no one in help ........
You can activate the fog lights and have the cornering function, in fact turning on a curved fog lamp as the fiat 500L originates.
I say that I activated the fog lights with correct operation, missing the cornering function (turning on only one curved fog)
alex-et3
Post by alex-et3 »
Roberto0187 wrote:Good evening, no one in help ........
You have to ask Yani if you can activate this function.
Roberto0187
Thank you for the reply,
how can i ask yani how can i enable the function in proxy can.
I add that when I did the activation of the fog lights in the proxy, I did not succeed with the last unit I think the car radio.
However, even though it has failed, I activated the fog lights with ignition via the original keyboard only retro-light, now I do not want the problem to be this.
As a proxy writing error I was given time out error.
alex-et3
Post by alex-et3 »
No, I think there is a special activation to do.
Roberto0187
alex-et3 wrote:
Roberto0187 wrote:
alex-et3 wrote: You have to ask Yani if you can activate this function.
then I just have to hope for Yani help.
do I have to wait for a response here or there is a section to make this request?
alex-et3
Post by alex-et3 »
Roberto0187 wrote:
alex-et3 wrote:
Roberto0187 wrote: Thank you for the reply,
You have to contact him through MP
Cicifan
Post by Cicifan »
Hi. News? I have same problem in my Fiat Tipo. Thank you.
-----EDIT------
Thanks all. Fiat car service called me some days ago, and i visited the service, and my problem solved. (Fiat Tipo) Now working perfectly like the stock. He tell me, needed to change some 'hidden' settings with programming in the daytime running lights section. And after activated. Similar method like other newer Fiat models settings.
Roberto0187
Cicifan wrote: 27 Feb 2020, 05:25 Hi. News? I have same problem in my Fiat Tipo. Thank you.
Write a pm to yani, he gave me the proxy change. In case you try to post me your proxy, I have one that I have activated the carplay let's see if it is the usual bite that changes.
