Fiat Bravo 99 without OBD
I have this cables:
409
Fiat 3 pin
But not works... why?
What should I do?
409
Fiat 3 pin
What should I do?
Re: Fiat Bravo 99 without OBD
You should check first that the cable is installed properly with FTDI drivers, and set as COM3 or COM4 or anyother you want to use.
Check in "Device Manager" it is displayed as COM3 in "Ports".
Then check if the red aligator is well connected to the battery positive(+) terminal.
It should be ok like this,
If it fails to connect, just try again.
If it continues failing the connection, cycle the ignition, OFF a few seconds, until you hear the relay switching, and then back ON.
It should work.
It should work.
which system want you connet to, what is the error message?
I think your Bravo 99 have the same order of the connections as my Marea '99.
The Engine ECU connection is on the right side (passenger side) dome.
Is the comport in the programm the same as it is in the Windows configuration?
Look at HowToUse.
Greets Bu11y.
Look at HowToUse.
Greets Bu11y.
which type od ecu exist in fiat bravo '99
If same as my Marea:
Airbag, ABS and Engine ECU's.
Greets Bu11y.
Greets Bu11y.
Thanks, 100% works, but not ABS avaible...
ABS is on the oder Dome, Driver site.
Airbag is in the car pasanger site, i don't know the name in english, this thing that you can opent to put things in it, behind of this
But in this version it is not aided, maybe in one next time.
Greets Bu11y.
Greets Bu11y.
I have some questions about Fiat 3 pin and OBD reduction.
7 and 15 pin in OBD connector is the same?
third pin in fiat 3 pin in car is free...is not connected
Need I ever connect K line in Fiat 3 pin in OBD to 7 pin?
sorry from my english, but i am from slovakia
Tak mi to napis po slovensky
ok.takze:
treti pin redukcie, K, ktory ide na 7 pin OBD zasuvky nie je zbytocny? ved ci motorova zasuvka alebo abskova ma aj tak len 2 piny funkcne, treti je prazdny...myslel som ze zasuvky bez obd, budu fungovat cez K linku , teda 7 pin obd zasuvky ale ako pozeram na tu redukciu tak idu po linke L a teda napaja sa na 15 pin OBD. Dobre vravim???
