VAG
Post by VAG »
metnes71 have you set up the conection in settings in the program to ELM327 V1.3?
metnes71
Post by metnes71 »
by vag
yes
Settings in the program to ELM327 V1.3? Where is this program
Other free programs worked
I had a multiscan sensor test
Sensors in the panel
GAlt
Post by GAlt »
Hi guys, i my elm is wifi from the type that i attached. Everything worked great...kline, CAN, but now, something wrong and CAN communication not work. If you have some tips to make it work again, i will be very grateful?
Best regards
slickkon
Post by slickkon »
Hi All, my Device cannot connect to car.. error is 'CAN not supportted' can it be modified?
Car is 2009 Fiat Bravo T-Jet
Thank you..
metnes71
Post by metnes71 »
[quote="metnes71"]help please
My car "for the 2010 model Fiat / Fiorino 1.3 MultiJet 75 HP emonatio the euro4"
I connected the device to pc no problem
I connected the car to the ECU no problem
Multiscan program recognized
but
Multiscan did not work any data
Multiscan gives photo messages!
What do I have to do
Elm327 to be modified
Elm327 will resist resistance
page number see you 226
breraB62
Post by breraB62 »
Hi all,
New to forum, but not to alfas!!
I have an elm327 usb 1.5 which i got from fleabay.
I have searched throught this post to see if anyone has the same and there is one but it differs from mine in that my board comes away completely from the unit.
Board - Back, LEDs
Board - Back, LEDs
Board - Main R2 (121) removed
1.5 Elm327
1.5 Elm327
I have full version of FES 3.6.2 and i would like to reset the service indicator on my 2007 159 1.9JTDM as i now service it myself. Is it possible with the unit i have? I have already removed the R2 (121) resistor? I am having connection problems i.e. ATZ timeout etc which i will resolve, but just wanted to know if the unit i have will do the job i need.
I have attached images of the unit i have
Regards
John86
Post by John86 »
Hi all. I bought this interface and i want to know which resistor and capacitor should be removed to work properly with FiatMultiecuscan. I think the R3 121 ohm must be replaced, but I'm not sure. Thanks for help.
arcondi4
Post by arcondi4 »
Hi friends.
Need help.
I have ELM327 mini and I have no network access to can.
Look at the photos.
Do I need to remove a resistor?
What?
Can you post the photos, please?
oskar69
Post by oskar69 »
Hi Guys,
iam buy ELM327 V2.1 OBD2 - i have MESU 3.7 Registred.
in PC is all installed and works fine, but iam able connetct only to engine.
my qestion is, are some resistor for remove in this version ?
oskar69
Post by oskar69 »
I found this ...
check by Multimeter
and tested on my Stilo MW 2003 JTD - all works fine
solution was remove this resistor
